CTR or ITR cams?
Old Mar 26, 2004 | 10:25 AM
opiumdaze's Avatar
Default CTR or ITR cams?
i have a B18C with type r cams and i was told from somebody in a different forum that ITR cams only have good high end and CTR have good mid range and same high end of an ITR. would it be wise to change it to CTR because im pulling the head off soon and upgrading the valve train. is my statement true or false and give me an answer thanks
Old Mar 26, 2004 | 12:55 PM
94b18c1's Avatar
Default Re: CTR or ITR cams? (opiumdaze)
yes go ctr!!
Old Mar 27, 2004 | 03:37 AM
Xsi's Avatar
Xsi
They are very similar, generally CTR's are more aggressive but if you already have ITR's theres little gain in switching.
Try a search for a lot more info.
Old Mar 27, 2004 | 08:02 AM
92b16vx's Avatar
What year are your cams? 00+ they are the same.
Old Mar 27, 2004 | 09:12 AM
zad5's Avatar
yup 00-01 itr cams are the same the difference between the old itr cams and ctr is only on the intake cam and it has a little more duration i believe +3 more.
Old Mar 27, 2004 | 09:27 AM
SuperSteve737's Avatar
https://honda-tech.com/zerothread?id=741347
Old Mar 27, 2004 | 10:45 AM
92b16vx's Avatar
Default Re: (slo_dx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slo_dx &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=741347</TD></TR></TABLE>
What does a thread comparing CTR cams to Skunk2 cams have to do with comparing CTR's to ITR's?
Old Apr 1, 2004 | 04:34 PM
opiumdaze's Avatar
i have 2000 ITR cams so there is no difference in the CTR then? thanks
Old Apr 1, 2004 | 04:58 PM
mmuller's Avatar
Mad Scientist
Default Re: (opiumdaze)
the difference is neglible....
you really or the dyno wont notice the difference...maybe like 1hp
Old Apr 1, 2004 | 06:06 PM
Kendall's Avatar
Default Re: (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">you really or the dyno wont notice the difference...maybe like 1hp </TD></TR></TABLE>
Exactly, and this is only if comparing the CTR's to the early ITR cams.
Old Apr 1, 2004 | 06:43 PM
NyStreet's_4life's Avatar
Default Re: (Kendall)
yes 00 itr cam's are the same as ctr cam's
b18c1sircivic
Apr 8, 2008 04:49 PM
integraboosted
Aug 18, 2006 04:40 PM
kenepo_vtec
Jul 4, 2004 08:57 PM
JDMlyfestyle
Nov 1, 2003 06:26 PM
EJ8 Kenobi
Oct 23, 2002 05:01 PM
