Installing TurboXS Dual Stage Boost Controller Switch
Old Mar 26, 2004 | 04:37 AM
NapTownSi's Avatar
Default Installing TurboXS Dual Stage Boost Controller Switch
Where are you all tapping the 12V ignition fused power from for the toggle switch? I tried the cigarette lighter power wire, but I kept blowing the fuse every time I started the car. Is there a recommended spot? I spoke to someone from TurboXS yesterday and they told me to just solder it into the IGN2 (constant ignition voltage even when the starter is activated...much like a turbo timer), but that would need much lower gauge wire (I think the switch uses 18-22AWG. Thanks in advance for your help.
-Mark
Old Mar 26, 2004 | 04:50 AM
littlebluecrx's Avatar
Default Re: Installing TurboXS Dual Stage Boost Controller Switch (NapTownSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NapTownSi &raquo;</TD></TR><TR><TD CLASS="quote">Where are you all tapping the 12V ignition fused power from for the toggle switch? I tried the cigarette lighter power wire, but I kept blowing the fuse every time I started the car. Is there a recommended spot? I spoke to someone from TurboXS yesterday and they told me to just solder it into the IGN2 (constant ignition voltage even when the starter is activated...much like a turbo timer), but that would need much lower gauge wire (I think the switch uses 18-22AWG. Thanks in advance for your help.
-Mark</TD></TR></TABLE> you can run it there, the wire that comes with the controller is meant for that type of current load, we have run these with 16 volt bateries just fine, besides you shouldnt drive around on high boost all the tme anyways, so it wont be getting hit with the load all the time.
Old Mar 26, 2004 | 05:22 AM
showtymers619's Avatar
* B A N N E D *
Default Re: Installing TurboXS Dual Stage Boost Controller Switch (littlebluecrx)
i say.. run your own from the battery.. so you can use your own size wire and fuse size....so you wont run into any wiring problem later on
Old Mar 26, 2004 | 06:53 AM
NapTownSi's Avatar
I'm a schmuck! I mounted my switch right on the center shift console (in front of the little tray between the e-brake and the shifter)...well, when I pushed the console back together, the metal supports on the outside of the shifter area were shorting out the switch. So, when the car turned on, the power was essentially being grounded out and causing the fuse to pop. I'll try covering the terminals or relocating the switch. Thanks for the help.
-Mark
6genocide6
Nov 28, 2024 03:30 AM
simjosh
Jun 5, 2018 06:01 PM
trianglegreg
Feb 23, 2008 02:42 PM
thatasiankidtony
Audio / Security / Video
Nov 7, 2006 02:18 PM
jazz215
Jun 26, 2004 09:04 PM
