Boosted LS with Precision SC34
Old Mar 25, 2004 | 07:57 PM
VNTEC's Avatar
B A N N E D
Default Boosted LS with Precision SC34
Should i go with .48 Trim or .63 trim? Plans in the future are maybe a ported head with turbo cams (ditched my LSVTEC idea) I'm ready to buy now so lemme know what i should get.. Thanks
Old Mar 25, 2004 | 08:12 PM
InTeGrA B18b1's Avatar
Default Re: Boosted LS with Precision SC34 (VNTEC)
are you wanting high horsepower .63 or quick spool and good power .48 your choice. should be a easy choice.
Old Mar 25, 2004 | 08:22 PM
VNTEC's Avatar
B A N N E D
Well basically i want good USABLE power in my ls.. if i knew how to read compressor maps i would... I want good spool that will bring me to the stock redline of a LS..... so is a .48 fine or would a .63 do better?
Old Mar 25, 2004 | 08:57 PM
CaptainMorgan's Avatar
get the .63 you'll love it. but i think you should get a vtec head. My .63 is all maxed out. At 6000 rpm that is where my peak hp is, and all of a sudden my power is lost. I lose about 100 hp and 100 tq from 6000 to 7200. And it is all because of the ls head thats haveing the problem. I have crower turbo cams, crower springs, and ported head. Its sucks to loose that much power.
Old Mar 25, 2004 | 09:42 PM
Timmay's Avatar
Default Re: Boosted LS with Precision SC34 (CaptainMorgan)
im in the same bind right now to. stock b18b with 450's, s-afc and 9lbs
im thinking .63 but .48 may work well to, 7200 rev limit sucks
Old Mar 25, 2004 | 10:00 PM
Blackack26's Avatar
Default Re: Boosted LS with Precision SC34 (Timmay)
Do yourself a favor and get the .63, the lag is not that bad, really. I have a SC50 on my stock ls and it is great, love the top end power. I can drive it around daily without even seeing boost, but I know its there waiting muahahhaa. Only thing I hate is rolling into 3rd, I hate my ls tranny for that.
Old Mar 25, 2004 | 10:11 PM
DENCIO's Avatar
Default Re: Boosted LS with Precision SC34 (Blackack26)
what rpm is the full boost on the .63? I just bought a garret .63 stage 3 wheel 60 trim..building up my 91LS..so far I got eagle rods,cp pistons,acl bearings on the stock sleeves..thanx to camp1320 for hooking me up
Old Mar 25, 2004 | 10:17 PM
BlackKnight7's Avatar
At 9 psi the .48 should pull hard to redline. I run a 14b which has an even smallere a/r than .48 and it does. In fact I know guys who run 20 psi and pull hard to redline. I don't understand why so many people run such big a/r's when they only plan on running under 10 psi on stock internals. There is little gain by running such a large a/r for this setup. Unless you like lag I guess.
Jake D.
Old Mar 25, 2004 | 10:20 PM
Blackack26's Avatar
Default Re: Boosted LS with Precision SC34 (BlackKnight7)
I went with the .63 for two reasons...
1) I bought my basically brand new SC50 for $475
2) So when I do build the motor, I dont have to worry about upgrading the turbo
Old Mar 25, 2004 | 10:22 PM
Blackack26's Avatar
Default Re: Boosted LS with Precision SC34 (hookonboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hookonboost &raquo;</TD></TR><TR><TD CLASS="quote">what rpm is the full boost on the .63? I just bought a garret .63 stage 3 wheel 60 trim..building up my 91LS..so far I got eagle rods,cp pistons,acl bearings on the stock sleeves..thanx to camp1320 for hooking me up </TD></TR></TABLE>
Full boost for me (7 pounds) is about 4000rpm in 2nd if I roll into it. Oh how I love 2nd. First gear builds boost, not sure exactly how much, always watching the tach (and road ) cause 6875 comes up really fast.
If I redline first it will spin at the top, shift to second (depending on road conditions) will usually spin for a couple of seconds then grab. If I roll into second it holds traction (bairly) and pulls really hard.
but anyway, .63 is fun
Old Mar 25, 2004 | 10:30 PM
Timmay's Avatar
i think im going to do .48 casue i wont be over 9lbs for a while
ndogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blackack26 &raquo;</TD></TR><TR><TD CLASS="quote">I can drive it around daily without even seeing boost, but I know its there waiting muahahhaa.</TD></TR></TABLE>
this is exactly how i feel. get the 63 y0!
Old Mar 26, 2004 | 12:50 AM
shermanyang's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CaptainMorgan &raquo;</TD></TR><TR><TD CLASS="quote">get the .63 you'll love it. but i think you should get a vtec head. My .63 is all maxed out. At 6000 rpm that is where my peak hp is, and all of a sudden my power is lost. I lose about 100 hp and 100 tq from 6000 to 7200. And it is all because of the ls head thats haveing the problem. I have crower turbo cams, crower springs, and ported head. Its sucks to loose that much power. </TD></TR></TABLE>
you sure it's not your tuning?? all i have is a ported head (done by myself) and my whp is stable (+/- 5 whp) from 6k all the way to 7.2k.
anyway, try getting the .63 like everyone else says...you won't regret it
Old Mar 26, 2004 | 06:53 AM
Default Re: Boosted LS with Precision SC34 (shermanyang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shermanyang &raquo;</TD></TR><TR><TD CLASS="quote">
I don't think its tuning, because i have seen a lot of LS dyno and they all do that.
korre07
Apr 24, 2008 02:22 PM
redlseg
Jun 29, 2005 09:34 PM
egvtec
Nov 26, 2004 04:00 PM
DIRep972
May 5, 2002 09:04 PM
