My question for all you smart honda guys!
Old Mar 24, 2004 | 06:18 PM
BLiTZ BLuE CiViC's Avatar
Default My question for all you smart honda guys!
Ok, I have a d16y8 that i swapped into my del sol. I can be at a stop light, take off in first, and everything is fine, but when i shift into second gear, i can be going down the road and my cars tranny will pop out of second and go into neutral, what is wrong with my car? Please help soon!?!?!?
Old Mar 24, 2004 | 06:19 PM
MrIllegalX's Avatar
really bad shifter bushings?
Old Mar 24, 2004 | 06:20 PM
1SOL2NV's Avatar
Default Re: My question for all you smart honda guys! (BLiTZ BLuE CiViC)
could be your shift fork thats what happened to mine
E-brake or Handbrake's Avatar
Check clutch & tranny fluid. My brother's car does the same, so he ordered an Exedy kit.
Old Mar 24, 2004 | 06:21 PM
hayabusa160's Avatar
Default Re: My question for all you smart honda guys! (EG1B7)
my friends 87 celica dose the same in 4th its crazy
Old Mar 24, 2004 | 06:25 PM
Discosteak's Avatar
you should check your tranny for fluid it may have very little or way too much
Old Mar 24, 2004 | 07:06 PM
snatch13's Avatar
could be the synchros... does the same thing in my car when i slow down in 3rd... i was told i need new sychros but im gonna try some gm synchromesh before i do that cuz i might as well rebuild the transmission
Old Mar 24, 2004 | 08:52 PM
wisjdmhonda's Avatar
Default Re: My question for all you smart honda guys! (snatch13)
think it may be syncro's mine did that..... mine was really bad though.
Old Mar 24, 2004 | 08:55 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: My question for all you smart honda guys! (wisjdmhonda)
synchros wont make it pop out of gear...sounds like a shift fork problem or shifter assembly inside the tranny.
I've seen bad clutches cause this also...but you'll need to take a look at the tranny to figure it out
Old Mar 24, 2004 | 08:59 PM
sohcvtec1995's Avatar
Default Re: My question for all you smart honda guys! (Emerika)
Check your tranny fluid. Mine popped out of fifth and then my tranny went out on me.
Old Mar 24, 2004 | 09:00 PM
IS3Fifty's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika &raquo;</TD></TR><TR><TD CLASS="quote">synchros wont make it pop out of gear...sounds like a shift fork problem or shifter assembly inside the tranny.
I've seen bad clutches cause this also...but you'll need to take a look at the tranny to figure it out</TD></TR></TABLE>
A friend of mine has a hatch that does that. It was his clutch
Old Mar 24, 2004 | 09:02 PM
IWearMyKswiss's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika &raquo;</TD></TR><TR><TD CLASS="quote">synchros wont make it pop out of gear...sounds like a shift fork problem or shifter assembly inside the tranny.</TD></TR></TABLE>
my 5th gear kept on popping out of gear,..turned out to be the synchro
Old Mar 24, 2004 | 09:03 PM
Kamin's Avatar
Default Re: My question for all you smart honda guys! (TODAeg6)
odds are its a shoft fork, a syncro would have to have some odd damage to cause that.
Old Mar 24, 2004 | 09:17 PM
OpTiX619's Avatar
Default Re: My question for all you smart honda guys! (Kamin)
had the same problem with a d16y7, replaced the tranny with an d16y8 tranny, sold the old one because i did not want to fix a dx tranny. no more problems
Old Mar 25, 2004 | 02:47 AM
StreetProjectz's Avatar
Default Re: My question for all you smart honda guys! (OpTiX619)
shift fork
relinerokr
Dec 18, 2008 08:42 PM
CivicEKCP
14
Dec 23, 2004 02:46 PM
coupe_hybrid
Sep 8, 2004 08:22 AM
AzntaggeR
Aug 10, 2003 06:38 AM
Dru-Si
Apr 6, 2003 12:01 AM
