need oil pump for my b20 set up which to pick?
Old Mar 23, 2004 | 01:41 PM
showtymers619's Avatar
* B A N N E D *
Default need oil pump for my b20 set up which to pick?
can i use vtec pumps without getting a new timing belt? im getting confused... if it was getting a new belt cuz of the vtec head and oil pump.. or was it just oil pump? .. its a straight b20 set up...
Old Mar 23, 2004 | 01:44 PM
Rod.'s Avatar
Default Re: need oil pump for my b20 set up which to pick? (ShowTymers619)
just get the b20 it is the same as the gsr...what i read somewhere
Old Mar 23, 2004 | 01:47 PM
porsche997dc2's Avatar
Default Re: need oil pump for my b20 set up which to pick? (redturbocivic)
If your timing is old then replace it at the same time. If the said "xxxx-pr3 or p72-xxxx" then it's a vtec oil pump.
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">just get the b20 it is the same as the gsr...what i read somewhere</TD></TR></TABLE>
i heard the same thing but i heard its the same as a ITR... flow wise that is... not sure on the part number tho... can any1 clairify...i need to kno i might need extra oil pressure for my turbo set up
Old Mar 23, 2004 | 01:51 PM
* B A N N E D *
found the part number.... heres a thing for it if any1 needs info about b20's
oil pump 15100-p72-A01 Same as GSR, and ITR
Old Mar 23, 2004 | 01:53 PM
yes, it's a vtec pump. I just check with the honda dealer. For 98 crv(b20), it's a "15100-p72-Ao1".
Old Mar 23, 2004 | 03:52 PM
99B16Si's Avatar
all the replacement oil pumps for obd2 cars are the same
Old Mar 23, 2004 | 05:49 PM
AlphaMike's Avatar
Default Re: (99B16Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99B16Si &raquo;</TD></TR><TR><TD CLASS="quote">all the replacement oil pumps for obd2 cars are the same</TD></TR></TABLE>
Yup, OBD2 GSR, B20, and ITR are all the same oil pump...
champwhiteEG6
Mar 31, 2017 09:26 PM
MI4$DC5
Jul 19, 2008 12:16 PM
MyTEC4
May 22, 2006 07:13 PM
RTW DC2R
Jul 2, 2004 07:07 AM
another_import
Oct 21, 2002 06:30 PM
