b16 head on a b18 block
Old Mar 22, 2004 | 05:12 PM
cincispeedemon's Avatar
Default b16 head on a b18 block
I'm no where near a Honda mechanic, so bear with me.
If I out a b16 head on my b18 block, that would be similar to an ITR motor, correct? Keep in mind it's a b18a1.
If I did this,
#1 would it be worth it?(hp wise)
#2 would it be worth while to set this head up for F/I ?
#3 Would I need a b16 ecu, or b18 ecu for the vtec?
Old Mar 22, 2004 | 05:13 PM
RidinStock's Avatar
Default Re: b16 head on a b18 block (cincispeedemon)
Do a search for LS/VTEC, because that is exactly what you are trying to build.
Old Mar 22, 2004 | 05:14 PM
Default Re: b16 head on a b18 block (RidinStock)
oh, will do , thanks.
:edit:
I searched and came up with nothing, I'm probly doing it wrong. Any ways would the b16 head be worth it, if not I don't care about the vtec.
Old Mar 22, 2004 | 08:25 PM
RidinStock's Avatar
Just click the upper-right search button, enter lsvtec, and hit search. I came up w/ like 90 results, and you can also search the archived content.
I don't know about it being close to an ITR motor, but I have read a lot about ls/vtec on h-t. basically your getting the advantages of the vtec head and stock b18 bottom end. Here's my best shot to answer your questions, I'm no expert... just an H-T reader...
#1 - It puts out more HP than your B18, but I have no idea how much, never built one.
#2 - It can be set up for F/I w/ the right internals, and from what I've read it's pretty damn fast. Hopefully someone else has some more input for you on this.
#3 - I think you can keep the B18 ECU, because if you don't upgrade the internals, your redline shouldn't really change... but later on you probably want to upgrade to an aftermarket to help w/ performance.
I hope that information helps, and if i'm wrong, H-T users please be quick to correct me. Best thing you can do is search.
Old Mar 22, 2004 | 08:37 PM
Kendall's Avatar
Search for "lsvtec" resulted in 59 recent topics and 482 topics in the archives. That should keep you busy for a while.
Old Mar 22, 2004 | 09:30 PM
cyvic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RidinStock &raquo;</TD></TR><TR><TD CLASS="quote">Just click the upper-right search button, enter lsvtec, and hit search. I came up w/ like 90 results, and you can also search the archived content.
I hope that information helps, and if i'm wrong, H-T users please be quick to correct me. Best thing you can do is search. </TD></TR></TABLE>
#3 need vtec ECU with same OBD as the car.
but the first thing you need to do is Research, Research!
Old Mar 22, 2004 | 09:44 PM
FastSS's Avatar
It will make more HP as a function of it reving to 8000... which is risky
With the right internals ANY motor can be set up for FI, LSVTEC is a very hack way of doing a "custom length" rod/crank combo vtec motor...
I do not know if the block deck height is taller (I normally measure from the center of the crank shaft to the top of the block, I believe this is normal)
Obviously the rod/stroke ratio is different...
The only reason I will ever build an LS vtec is just so I can say I have done it
Basically any motor I build is built to my specs... under those circumstances only a fool will go out in search of an LS block and vtec head to make an engine... normally ill just buy a b18C swap from Hmotors online and tear the bitch apart, rebuild it to JSpec (John Spec)
Old Mar 22, 2004 | 10:49 PM
Slain's Avatar
alot of ppl are trying the b18c block with ls crank ( aids in a bit more displacement)
Old Mar 24, 2004 | 05:38 PM
Default Re: b16 head on a b18 block (FastSS)
I've decided on backing down from the ls/vtec, it's to risky to add boost.
Old Mar 24, 2004 | 05:41 PM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cincispeedemon &raquo;</TD></TR><TR><TD CLASS="quote">I've decided on backing down from the ls/vtec, it's to risky to add boost.</TD></TR></TABLE>
It's risky to add boost to anything.
jdm.boi408
Aug 30, 2010 05:13 PM
parfait2882
Dec 12, 2006 03:05 PM
JDMLEROY
May 24, 2005 09:45 AM
Pre1ude
Sep 20, 2004 12:57 PM
b16si
Feb 8, 2004 07:37 AM
