Exedy organic clutch kit vs act street kit
Old Mar 22, 2004 | 04:15 PM
JFG Kevin's Avatar
Default Exedy organic clutch kit vs act street kit
which one should i got with? i have a cai rite now..rest if stock...future plans...very soon...exhaust (n1) header comptech (TIG), cams, cam gears, skunk 2 tb...
Old Mar 22, 2004 | 09:43 PM
JFG Kevin's Avatar
Default Re: Exedy organic clutch kit vs act street kit (aznstyler119)
Bump
Old Mar 23, 2004 | 12:03 AM
WhoisDan's Avatar
I would like to know as well. The only reason why I would go with Exedy is because they are a lot cheaper. Ebay has good deals. But if I have the money, I rather go with ACT.
Old Mar 23, 2004 | 03:42 AM
Radon_03's Avatar
Default Re: (whoisdan)
Just put the Exedy on last week with their 9lb flywheel. So far I have been happy. Pedal pressure is slightly greater and the flywheel seems to make a difference as well. Car seems slightly quicker and I definately notice it when downshifting. Got the whole setup for 545 shipped. http://www.coximport.com has pretty good prices for Exedy stuff.
Old Mar 23, 2004 | 07:00 AM
pm6825's Avatar
I have an ACT clutch on my GSR and it is phenomenal. When I drove my friends stock GSR it felt so ridiculously soft i had problems getting used to it. I went with ACT just b/c of their reputation for making the best clutches. I was thinking about an Exedy clutch b/c Exedy makes the stock clutches for Hondas/Acuras. But I went with the ACT in the end.
Old Mar 23, 2004 | 10:08 AM
JFG Kevin's Avatar
Default Re: (pm6825)
i was thinking about getting hte streetlite ACT flywheel 12lb...and exedy organic clutch kit....good set up?
Old Mar 23, 2004 | 10:32 AM
Two_K Si's Avatar
Default Re: (aznstyler119)
Exedy organic and exedy flywheel is a very nice combo I dont think you would realy notice a difference with a 12 pound flywheel compared to stock.
Old Mar 23, 2004 | 12:02 PM
disboilikehoy's Avatar
Well i have a ACT 6 puck xtreme and it catches really good just its too strong and i break stock axels like every 2 or 3 weeks
Old Mar 23, 2004 | 12:21 PM
IntEGNYC's Avatar
Default Re: (disboilikehoy)
i have an exedy organic clutch and a 12lbs ACT flywheel waiting to be installed. probably do it later this year after the clutch wears down a bit more.
Old Mar 23, 2004 | 04:29 PM
FR-MOB: ThE bEe GuY's Avatar
Default Re: (IntEGNYC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntEGNYC &raquo;</TD></TR><TR><TD CLASS="quote">i have an exedy organic clutch and a 12lbs ACT flywheel waiting to be installed. probably do it later this year after the clutch wears down a bit more.</TD></TR></TABLE>
Exact same setup im getting put into my DA right now. Im a diehard Exedy fan. Had the organic clutch in my CRX and LOVED IT. THats why i bought another one for my Integra
Old Mar 23, 2004 | 06:26 PM
mingbling's Avatar
Default Re: (ThE bEe GuY)
just installed an exedy STOCK replacement clutch and an XACT 8.8 lb flywheel. Works very well, and chirp 3rd easily too. The stock replacement clutch seems so far to be handling the slight abuse very well.. You might want to consider that
Old Apr 7, 2004 | 06:37 PM
SpoonTeg's Avatar
how can you tell between the stock replacement and the race version????
Old Apr 7, 2004 | 07:05 PM
Rory Breaker's Avatar
Default Re: (SpoonTeg)
I would go ACT over Exedy if you plan on doing anything other than normal, daily, in and out driving.
ACT HDSS is the way to go in terms of a mild upgrade.
Old Apr 7, 2004 | 07:20 PM
spoolindc2's Avatar
I went w/ ACT organic n xtreme press. plate and a pro lite fly wheel love it!
Old Apr 7, 2004 | 07:23 PM
HondaGuy02's Avatar
Banned
Default Re: (newgsrdriver)
i have heard nothing but good things about ACT, and i have heard both good and bad things about exedy. I have personally used a ACT 6 puck clutch and it seemed to work fine, no problems what so ever.... only complaint... too extreme for street use, more annoying then anything else. But i was able to chirp 4th with a stock LS integra.
Iloveyourhonda92
Jun 29, 2012 07:10 AM
Bsharpe
Apr 22, 2010 03:52 AM
s2kimportlover
Honda S2000
Jan 31, 2009 07:01 AM
BustedEG
Jul 27, 2004 10:37 AM
VoltageLS
Mar 16, 2003 01:34 PM
