Exedy vs ACT clutch
Old Mar 15, 2003 | 09:08 PM
VoltageLS's Avatar
New User
Default Exedy vs ACT clutch
What's up guys, debating between an Exedy organic clutch and an ACT unit. I'm pretty settled on the ACT xACT street flywheel (12.5lb) just needa make the choice on clutch. Would the ACT one be better since i'd be using an ACT flywheel? Mainly looking for personal testimonys. Thanks
Old Mar 15, 2003 | 10:37 PM
Jeff C's Avatar
Default Re: Exedy vs ACT clutch (VoltageLS)
I am using an Exedy Organic w/ CM flywheel and it is holding up for me. Although, I am not making mega power.
https://honda-tech.com/zerothread?id=438747
Old Mar 15, 2003 | 11:34 PM
sgT's Avatar
sgT
Default Re: Exedy vs ACT clutch (Jeff C)
ACT is an upgrade
Exedy is a stock replacement, expect of it what you would of a stock clutch
Old Mar 16, 2003 | 12:02 AM
qtiger's Avatar
Default Re: Exedy vs ACT clutch (sgT)
ACT is an upgrade
Exedy has stock replacements as well as sports clutches. Just because it's made by Daikin doesn't mean its a stock replacement.
Old Mar 16, 2003 | 07:49 AM
B16A1-EF9's Avatar
Default Re: Exedy vs ACT clutch (qtiger)
All clutch manufacturers use stock pressure plates and then rebuild them and make them stronger. If you see the EXTREME ACT...and even the better ones, the PP looks like a stock on just beefed up.
EXEDY is the only clutch manufacturer that makes their own pressure plates. If you see the multi-disc high horsepower clutch system from EXEDY you'll understand why EXEDY is actually better then all the rest.
Old Mar 16, 2003 | 09:53 AM
sgT's Avatar
sgT
Default Re: Exedy vs ACT clutch (B16B-EF9)
every exedy i have ever seen has failed. I would never buy one nor would i
recommend one to anybody.
Their line about the best selling clutch in japan is a joke. THey only sell the most
because they are so damn cheap all the auto mfgs buy them for stock clutches.
Nobody uses exedy for aftermarket.
Old Mar 16, 2003 | 01:34 PM
HotWheelz's Avatar
ACT extreme, CM flywheel.. here
danny98r
Jun 24, 2004 12:15 PM
Manguish
Jun 14, 2003 01:26 PM
EH2DX
Aug 16, 2002 02:03 AM
vteg
Apr 22, 2002 01:05 PM
