ls vtec over heating problem
Old Mar 19, 2004 | 02:31 PM
SprayinCX's Avatar
Default ls vtec over heating problem
well here is what i have:
94 ls shortblock
00' si head
here is what i have done:
changed headgasket on it twice
changed thermostat
changed coolant temp switch
flushed the coolant system
and it still idles at around 180 degrees whick is what the the thermostat is but when i go for the test drive it will go up to 210 or even 230. i have all i can think of. anyone else got any ideas.
Old Mar 19, 2004 | 03:12 PM
SpoonyGSR's Avatar
I hate rap music
have you bleed the coolent lines? make sure all clamps are tight, i had a problm with over heating and it tuned out to be a hose that wasent clamped well enough, i found it and clamped it and it never happened again. also it might be radiator cap, or even the radiator. check water pump too, but most likely you will hear a noise with that. could be all of those things.
ohh your head or block could be warped, and makes it not get an even seal.
Old Mar 19, 2004 | 04:39 PM
SprayinCX's Avatar
Default Re: (spoonie_GSR)
okay nevermind i got it.
i listened to a idoit instead of my own ability.
Old Mar 19, 2004 | 05:38 PM
SpoonyGSR's Avatar
I hate rap music
i hope your not talking about me being an idiot
Old Mar 20, 2004 | 02:09 AM
JBBNJ609's Avatar
Default Re: (SprayinCX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SprayinCX &raquo;</TD></TR><TR><TD CLASS="quote">okay nevermind i got it.
i listened to a idiot instead of my own ability.</TD></TR></TABLE>
can you explain this post better then that
how did you fix it ??
Old Mar 20, 2004 | 05:00 AM
SprayinCX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonie_GSR &raquo;</TD></TR><TR><TD CLASS="quote">i hope your not talking about me being an idiot</TD></TR></TABLE>
no not you. it is a local guy.
yea the autometer sending unit can't be mounted on the side of a b16 head cause it is to long so you have to relocate it somewhere else.
Old Mar 20, 2004 | 09:48 AM
zensoku207's Avatar
autometer sending unit??
Old Mar 23, 2004 | 03:46 AM
SprayinCX's Avatar
Default Re: (zensoku207)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zensoku207 &raquo;</TD></TR><TR><TD CLASS="quote">autometer sending unit??</TD></TR></TABLE>
yea the autometer electrical gauge a post that you put inline with the coolant and the gauge reads the temperature from it.
Old Mar 23, 2004 | 08:51 AM
zensoku207's Avatar
coo
Peruviann83
May 30, 2021 02:47 PM
nrst89
Jul 17, 2009 02:45 PM
slob20ef
Mar 30, 2009 05:56 AM
JODYG35950
Nov 2, 2005 08:26 AM
ls_vtec_b18a1
Nov 19, 2002 09:49 PM
