Phantom Grip LSD?
Old Mar 16, 2004 | 07:25 AM
JoeCivic's Avatar
Default Phantom Grip LSD?
I'm considering a phantom grip lsd for my d16z6 running 11psi.. Traction is a pretty serious problem right now. I know you can pick up the PG units on ebay for around 220 or so... sounds like the price is right to me. Anyone have experience or know anything about them? Its a clutch type system... how often will i have to pull the little bastard out and rebuild it?
Old Mar 16, 2004 | 07:27 AM
JoeCivic's Avatar
Default Re: Phantom Grip LSD? (JoeCivic)
Forgot to ask... how would it compare to a quaif unit, a kaaz unit or a stock unit? I know the gear type have very different characteristics than clutch type... but any additional info would be GREAT ! thanks in advance
Old Mar 16, 2004 | 07:35 AM
Kal's Avatar
Kal
phanton grip is not a true LSD, put your money with something in the lines of quaife..clutch type requires too much mantainence
Old Mar 16, 2004 | 10:01 AM
JoeCivic's Avatar
Default Re: Phantom Grip LSD? (kxkal)
What kind of maintainence is required?? lifetime warenty on the unit and what not. doesn't sound like it'll wear out. Has anyone ever used one?
Old Mar 16, 2004 | 11:45 AM
onePOINTsix's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kxkal &raquo;</TD></TR><TR><TD CLASS="quote">phanton grip is not a true LSD, put your money with something in the lines of quaife..clutch type requires too much mantainence</TD></TR></TABLE>QUAIFE IS A CLUTCH TYPE!!!!! same with KAZZ, phantom grips are cool as long as you install then correctly, if someone on here tells you dont because you'll blow your spider gears then they installed it wrong, i'd get a professionall to do it for you that has done one before
Old Mar 16, 2004 | 12:41 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoeCivic &raquo;</TD></TR><TR><TD CLASS="quote">I'm considering a phantom grip lsd for my d16z6 running 11psi.. Traction is a pretty serious problem right now. I know you can pick up the PG units on ebay for around 220 or so... sounds like the price is right to me. Anyone have experience or know anything about them? Its a clutch type system... how often will i have to pull the little bastard out and rebuild it? </TD></TR></TABLE>
I have one and am happy with it on my boosted z6. It took about 500 miles for it to seat in and start working though. BTW, it's doesn't have any clutches, it's basically two spring loaded plates.
Old Mar 16, 2004 | 12:51 PM
LudeLover's Avatar
hey, another person from the good ole 'noke
where about in roanoke are you? are you a member of dragva.com?
Old Mar 16, 2004 | 01:18 PM
RHD_BB4T's Avatar
Default Re: Phantom Grip LSD? (Sideout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sideout &raquo;</TD></TR><TR><TD CLASS="quote">QUAIFE IS A CLUTCH TYPE!!!!! </TD></TR></TABLE>
There are no clutches in a QUAIFE... at least not in MINE, they are 'gear-type'!!!
http://www.quaifeamerica.com/d...s.htm
Old Mar 16, 2004 | 04:08 PM
JoeCivic's Avatar
Default Re: Phantom Grip LSD? (RHD_BB4T)
Yea, quaif is def. a gear type. Thanks for the good info on the phantom grip... sounds like a winner to me... talk about bang for the buck..
i'm in the Cave Spring area... how about you? I'm on drag va too
Old Mar 16, 2004 | 05:31 PM
LudeLover's Avatar
cave spring eh? you the one w/ you looked or something like that on ur plates?
i'm in the Vinton area
my handle on dragva is 89silude although the lude is no more
and so that this post isn't COMPLETLY o/t . . .
good luck w/ the LSD!
Old Mar 16, 2004 | 05:48 PM
Kendall's Avatar
I personally would invest in the Quaife. The Kaaz units need to be rebuilt periodically and are thus dubbed as "high maintenance." And I've heard mixed reviews about the functionality (is that a word) of the Phantom Grip units during hard cornering. I would go with something proven, like a Quaife.
Old Mar 16, 2004 | 06:33 PM
Kal's Avatar
Kal
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RHD_BB4T &raquo;</TD></TR><TR><TD CLASS="quote">
exactly, yes quaife has been proven and is good. i suggest you choose that
Old Mar 16, 2004 | 06:39 PM
Sliced Beard's Avatar
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sideout &raquo;</TD></TR><TR><TD CLASS="quote">QUAIFE IS A CLUTCH TYPE!!!!! same with KAZZ, phantom grips are cool as long as you install then correctly, if someone on here tells you dont because you'll blow your spider gears then they installed it wrong, i'd get a professionall to do it for you that has done one before </TD></TR></TABLE>
you are INCORRECT
Quaife is a helical gear type lsd identical to what a ITR lsd is besides it has a tad thicker internals so it can hold higher amounts of hp
Old Mar 17, 2004 | 03:05 AM
JoeCivic's Avatar
Default Re: (dirtyd463)
Thx for all the great info guys
Na, nothing like that on the plates... just VT plates. What about you? where are you from?? and what do you drive?
angryhillbilly
Transmission & Drivetrain
12
May 11, 2013 04:44 PM
dblair
May 3, 2013 01:21 PM
4.8t
Feb 3, 2010 01:31 AM
Spade
22
Jun 15, 2002 11:39 AM
KekeK-18
Oct 22, 2001 01:23 AM
