got a bad vibration
Old Mar 16, 2004 | 07:21 AM
92Periwinkle's Avatar
Default got a bad vibration
a couple of days ago i noticed a strange vibration/sound. it almost sounds electrical, it shows up at light throttle around 2500-2800 rpm. it shows up again at full throttle all the way across the tach. there is also a noticeable loss in power. just wondering if you guys would have any idea as to what it might be. i really don't wany to hit the dealership to find out$$$. just replaced spark plugs and dist. rotor hoping it would fix it, no such luck.
thanks
Modified by 92Periwinkle at 11:51 AM 3/16/2004
Old Mar 16, 2004 | 09:23 AM
tuan...'s Avatar
Default Re: got a bad vibration (92Periwinkle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92Periwinkle &raquo;</TD></TR><TR><TD CLASS="quote">a couple of days ago i noticed a strange vibration/sound. it almost sounds electrical, it shows up at light throttle around 2500-2800 rpm. it shows up again at full throttle all the way across the tach. there is also a noticeable loss in power. just wondering if you guys would have any idea as to what it might be. i really don't wany to hit the dealership to find out$$$. just replaced spark plugs and dist. rotor hoping it would fix it, no such luck.
thanks
Modified by 92Periwinkle at 11:51 AM 3/16/2004</TD></TR></TABLE>
you got a bad VIBRATIONNNN, cmon cmon. i have the same prob at like 2500-3k but it goes away.
Old Mar 16, 2004 | 10:08 AM
Default Re: got a bad vibration (v0gueSilver_Dc2)
only problem is that is robbing me of power at full throttle. it's not a wheel vibration, it's an engine vibration that just started a few days ago.
Old Mar 16, 2004 | 10:28 AM
Sephro's Avatar
have you noticed if your tach is screwing up at all??
You might want to check your plugs. Make sure they are gaped correctly.
Also check your grounds. You might want to try adding another ground wire to the head.
Old Mar 16, 2004 | 01:01 PM
Mi4DUB's Avatar
Default Re: got a bad vibration (Sephro)
yeah, check the gap on the plugh and make sure you tq it down... if you under tq then you could be getting the bibe' from air escaping from the plug. gi ve it a shot
Old Mar 25, 2004 | 05:17 PM
Default Re: got a bad vibration (Mi4DUB)
just replaced the plugs with new platinum 4's, didn't solve any problems. also replaced the dist. rotor, also no difference.
Old Mar 26, 2004 | 08:46 AM
Sephro's Avatar
have you noticed your tach screwing up??
Old Mar 27, 2004 | 01:12 PM
nope, tach's been workin just fine, i'm startin to think it might be the air filter of all things. the vibration only shows up at 2900 rpm and at full throttle above 3500 rpm, correct me if i'm wrong, but don't the second set of butterflys open up about those times?
Old Mar 27, 2004 | 01:36 PM
Shakes's Avatar
space cadet
these guys got GOOD VIBRATIONS
but seriously. check all of your mounts, etc etc. make sure everything is tight.
bikeboy80
Acura TSX
Jun 24, 2020 05:18 PM
raverx3m
Engine Management and Tuning
May 30, 2015 05:10 PM
kwikiimart
Dec 20, 2010 03:24 PM
1fastEK9
May 9, 2008 07:11 AM
notstock93
Sep 1, 2004 09:20 PM
