blox 74mm throttleboby
Old Dec 18, 2007 | 08:09 AM
1fastEK9's Avatar
Default blox 74mm throttleboby
hello everyone I been looking at this blox 74mm tb, and I was wondering if anyone has any problems with it or good results thanks........
Old Dec 18, 2007 | 08:35 AM
boostfeen's Avatar
Default Re: blox 74mm throttleboby (1fastEK9)
..your prob. better off with RPM sevices or BDL 74mm throttle body.
95dc2teg's Avatar
thats huge....
Old Dec 18, 2007 | 10:21 AM
1fastEK9's Avatar
Default Re: blox 74mm throttleboby (boostfeen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostfeen &raquo;</TD></TR><TR><TD CLASS="quote">
..your prob. better off with RPM sevices or BDL 74mm throttle body. </TD></TR></TABLE>
do you know who sells rpm tb's at a decent price ?
Old Dec 18, 2007 | 10:44 AM
boostedeg302's Avatar
Default Re: blox 74mm throttleboby (95dc2teg)
what kind of power you plan on flowing through there
Old Dec 18, 2007 | 10:46 AM
Casey's Avatar
id bet theyre all made at the same place
Old Dec 18, 2007 | 11:30 AM
boostfeen's Avatar
Default Re: blox 74mm throttleboby (Casey)
id bet theyre all made at the same place</TD></TR></TABLE>
...alot of them are im sure, but not all of em.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1fastEK9 &raquo;</TD></TR><TR><TD CLASS="quote">
do you know who sells rpm tb's at a decent price ?</TD></TR></TABLE>
...Snail EG on here was i think. but yur better off with BDL TB. contact Laskeyracing
Old Dec 18, 2007 | 03:22 PM
ctr83's Avatar
bdl thay will not stick.
Old Dec 18, 2007 | 05:12 PM
schwitzerT's Avatar
Does anyone have Clonclusive proof that Bigger TB's work for Turbo Applications?
why whould one wanna put on a 70/74mm TB. on a F/I Car? all the Info i have read on the Bigger TB for F/I is only go once size bigger to defeat the restriction cause buy the butterfully its self...
Or how does it work?
Old Dec 18, 2007 | 05:22 PM
GraphiteAccord's Avatar
Default Re: (schwitzerT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schwitzerT &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone have Clonclusive proof that Bigger TB's work for Turbo Applications?
Or how does it work?</TD></TR></TABLE>
sorry to state the obvious here...but it helps, because it's more volume. Think of it as a water hose. a 2" hose at 35psi will only flow so much. But a 4" hose at 35psi will flow FAR more. That is what the OP is looking for, to put more air in.
Old Dec 18, 2007 | 05:56 PM
project dc2's Avatar
Default Re: blox 74mm throttleboby (boostedeg302)
we ran a few blox throttle bodies on our customer cars with no problem.
we test a lot of products before we sell them to confirm its a good product.
the price on these things are damn competitive compared to rpm service etcc
PM us if interested
Old Dec 18, 2007 | 09:27 PM
schwitzerT's Avatar
Default Re: (GraphiteAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GraphiteAccord &raquo;</TD></TR><TR><TD CLASS="quote">
sorry to state the obvious here...but it helps, because it's more volume. Think of it as a water hose. a 2" hose at 35psi will only flow so much. But a 4" hose at 35psi will flow FAR more. That is what the OP is looking for, to put more air in. </TD></TR></TABLE>
Yeah i agree with you on that but so many Sites say it makes no Differene!!! O well!!!<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 &raquo;</TD></TR><TR><TD CLASS="quote"> we ran a few blox throttle bodies on our customer cars with no problem.
PM us if interested</TD></TR></TABLE>
Im sure they are very gewd, they look the business. Just wish there was a chart were sumone could show the Positive Effects(Improvemnet in Performance) of a bigger TB(60,65,70,75) so i can finally prove all these other idiots wrong.
Old May 5, 2008 | 07:12 AM
EFbomb's Avatar
The box one looks identical to the RPM service. I own an RPM service 70mm on a Edelbrock IM on my turbo B16, still in pieces so i cant vouch for the performance yet, but larger diameter = more flow, so it has to be better
Old May 5, 2008 | 07:33 AM
Riake's Avatar
Default Re: (EFbomb)
then why not put a 100mm on there?
bigger in this case does not mean better
Old May 5, 2008 | 07:36 AM
balleur's Avatar
Default Re: (Riake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Riake &raquo;</TD></TR><TR><TD CLASS="quote">then why not put a 100mm on there?
bigger in this case does not mean better</TD></TR></TABLE>
troof!
Old May 5, 2008 | 08:55 AM
Tulo's Avatar
Default Re: (balleur)
Isn't the idea just to establish a smooth transition into the manifold(i.e. eliminate bottleneck)? If you have a 2.75 inch charge pipe, then you want a 2.75inch(~70mm) throttle body. Anything smaller and airflow will be slightly restricted. Smooth transitions ftw.
Old May 5, 2008 | 09:28 AM
CRX T-Si's Avatar
Default Re: (Tulo)
It all depends on what the power goals are.
It's like using an SC61 for 300whp, you can use it but it's not optimum....bigger is not always better everyone knows this.
Old May 5, 2008 | 11:27 AM
HybridKOOP's Avatar
Default Re: (CRX T-Si)
The smaller the throttlebody, the better the throttle response (within reason). The larger the throttlebody, the poorer the throttle response, but the ability to flow a larger volume of air (within reason).
Old May 5, 2008 | 12:22 PM
DragWerks's Avatar
Default Re: (HybridKOOP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridKOOP &raquo;</TD></TR><TR><TD CLASS="quote">The smaller the throttlebody, the better the throttle response (within reason). The larger the throttlebody, the poorer the throttle response, but the ability to flow a larger volume of air (within reason).</TD></TR></TABLE>
^^INTERNET MYTH #147: In my experience this goes out the window with forced induction. Read below...
PERSNONAL EXPERIENCE, not internet heresay&gt;&gt; I've used and tuned quite a bit of setups with aftermarket tb's and have made great power with them with no drivability issues at all! If you can get them to not stick, big bore throttlebodies are excellent for boost.
I happen to have a spare 74mm blox tb I'm going to throw on a 84x89 VTEC Build along with an edelbrock mani. I'll post the dyno printout soon...
Old May 5, 2008 | 06:00 PM
HiProfile's Avatar
Default Re: (DragWerks)
Once the TB is wide open, its essentially just a tube with a bar across it. To put it bluntly, the TB is rarely a restriction on a Honda. A larger TB may help, but if you knew anything about carbs or physics, the Venturi Effect allows air to compress further and travel faster as it encounters a restriction in a tube. Not much energy is used to force the air through the TB. Futhermore, each runner is like 1/6th the cross section (area) of the TB, and only have 1 runner injesting air at full speed at any given point. You are far more limited by the intake runners/cam lift than the TB.
There is a point where you will flow more air than the TB can really deal with, but thats at 500+ whp for a Honda TB. Consider how a t04e cover usually has a 2" ID outlet in most cases, but still supports over 500whp. And given that the outlet temp is ~100-150F higher than when it passes through the TB (uses more volume when hot)...
Know fact: Dyno just a cam that [overall] gives 20% more flow (lift/duration/etc) vs just a TB that offers a 20% larger cross section. On most Hondas, you'll gain far less by adding a TB than by adding an intake cam.
Old May 5, 2008 | 07:47 PM
ninesecrx's Avatar
Default Re: (HiProfile)
I agree, that Blox unit looks just like the RPM tb. BDL does make a few other company's stuff, but the blox is not made by them. BDL has a pretty good warranty if bought through a reputable dealer. So if there is issues with their tb's...they get taken care of which is nice for a company. Keep in mind the BDL unit is tapered from 74mm at the opening to 72mm at the butterfly.
Old May 6, 2008 | 04:15 AM
wabaki's Avatar
i just got my blox 74mm today. looks good and its def. going in my new build. fits a 3" hose and charge pipe perfectly.
Old May 6, 2008 | 05:17 AM
joe111599's Avatar
Default Re: (Riake)
lol
Old May 8, 2008 | 09:20 PM
EFbomb's Avatar
FYI the rpm service 70mm is larger diameter than the edelbrock victorX #4764 inlet. I had to take the setup to a machine shop to port match the mani to the tb.
Old May 8, 2008 | 09:43 PM
wantboost's Avatar
Who is Mr Robot?
a bigger throttle body with out porting the tb flange wont accomplish ****....
i personally run a 90mm tb.. but its a on a huge built motor.
