Tach wiring for a 93 civic HB
Old Mar 15, 2004 | 07:40 PM
poppycock's Avatar
Default Tach wiring for a 93 civic HB
I bought this tach w/o wiring instructions and i need help wiring it...like a diagram or something...i knwo i have to hook it up to my ignition coil...but i dunno what color wires go where...can anybody help me?
thanks
poppycock
Old Mar 15, 2004 | 07:44 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Tach wiring for a 93 civic HB (poppycock)
ok here goes. i am assuming it is an autometer.
red - ignition switched 12 volts
white - lights or dimmer
black - ground
green - tach signal
the tach signal goes to this blue wire goin to no where:
skip.two's Avatar
Default Re: Tach wiring for a 93 civic HB (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">ok here goes. i am assuming it is an autometer.
black - ground
green - tach signal
Old Mar 15, 2004 | 08:12 PM
poppycock's Avatar
Default Re: Tach wiring for a 93 civic HB (jL iLLuZiOnz 9)
and i assume this pic is the ignition coil....?
thanks
Old Mar 16, 2004 | 07:22 AM
BatuKing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poppycock &raquo;</TD></TR><TR><TD CLASS="quote">and i assume this pic is the ignition coil....?
thanks</TD></TR></TABLE>
no the pic is of the driver sides connectors located right above the shocktower towards the rear of the engine bay
Old Mar 16, 2004 | 07:34 AM
lohatch's Avatar
there is also a tach wire that runs to the back of your cluster. i dont know the color of it off the top of my head but if you pull your cluster and the wire will be located on the farthest LEFT plug you take out. the wire will run to a slot that doesnt have a gold line running into it on your cluster(asumming your cluster doesnt have a factory tach)
Old Mar 16, 2004 | 08:43 AM
dwnthehatch's Avatar
Default Re: Tach wiring for a 93 civic HB (lohatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lohatch &raquo;</TD></TR><TR><TD CLASS="quote">there is also a tach wire that runs to the back of your cluster. i dont know the color of it off the top of my head but if you pull your cluster and the wire will be located on the farthest LEFT plug you take out. the wire will run to a slot that doesnt have a gold line running into it on your cluster(asumming your cluster doesnt have a factory tach)</TD></TR></TABLE>
It's the blue wire on the left plug of your cluster.
Old Mar 16, 2004 | 08:50 AM
Discosteak's Avatar
sell the tach and buy an ex cluster looks 1000% nicer
Old Mar 16, 2004 | 09:24 AM
gabebauman's Avatar
http://www.overboost.com/story.asp?id=333
NineEightCivic
Jul 8, 2007 04:26 PM
JokerTypeR
Sep 11, 2005 09:34 AM
SOHC_MShue
Aug 10, 2005 02:07 PM
JokerTypeR
Jul 2, 2005 02:36 PM
Mike D
May 15, 2003 06:36 PM
