Tach wiring for a 93 civic HB
I bought this tach w/o wiring instructions and i need help wiring it...like a diagram or something...i knwo i have to hook it up to my ignition coil...but i dunno what color wires go where...can anybody help me?
thanks
poppycock
thanks
poppycock
Mr. Badwrench
Re: Tach wiring for a 93 civic HB (poppycock)
ok here goes. i am assuming it is an autometer.
red - ignition switched 12 volts
white - lights or dimmer
black - ground
green - tach signal
the tach signal goes to this blue wire goin to no where:
black - ground
green - tach signal
Re: Tach wiring for a 93 civic HB (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">ok here goes. i am assuming it is an autometer.
black - ground
green - tach signal
black - ground
green - tach signal
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poppycock »</TD></TR><TR><TD CLASS="quote">and i assume this pic is the ignition coil....?
thanks</TD></TR></TABLE>
no the pic is of the driver sides connectors located right above the shocktower towards the rear of the engine bay
there is also a tach wire that runs to the back of your cluster. i dont know the color of it off the top of my head but if you pull your cluster and the wire will be located on the farthest LEFT plug you take out. the wire will run to a slot that doesnt have a gold line running into it on your cluster(asumming your cluster doesnt have a factory tach)
Re: Tach wiring for a 93 civic HB (lohatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lohatch »</TD></TR><TR><TD CLASS="quote">there is also a tach wire that runs to the back of your cluster. i dont know the color of it off the top of my head but if you pull your cluster and the wire will be located on the farthest LEFT plug you take out. the wire will run to a slot that doesnt have a gold line running into it on your cluster(asumming your cluster doesnt have a factory tach)</TD></TR></TABLE>
It's the blue wire on the left plug of your cluster.
SOHC_MShue
08-10-2005 02:07 PM
