where is this leak coming form?!
okay, ive been noticing that im having to fill up my clutch master cylinder reservoir more often than not. My issue is, i dont know where the hell the leak is. I keep having to fill it up, and beg one of my girlfreind to help me bleed it
. Any help would be appreciated, as this is starting to get on my nerves.
chaz
. Any help would be appreciated, as this is starting to get on my nerves. chaz
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iwhichisme »</TD></TR><TR><TD CLASS="quote">okay, ive been noticing that im having to fill up my clutch master cylinder reservoir more often than not. My issue is, i dont know where the hell the leak is. I keep having to fill it up, and beg one of my girlfreind to help me bleed it
chaz</TD></TR></TABLE>
prolly each one of your girlfriends are taking turns emptying out your clutch reservoir ... lol
usually leaks are at master cylinder or the slave cylinder.
greg
. Any help would be appreciated, as this is starting to get on my nerves. chaz</TD></TR></TABLE>
greg
if u master cylinder seems fine, check ur slave cylinder.
just take a small pick or srcew driver and move the rubber boot on the slave cylinder, u would notice a good amount of fluid come out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake »</TD></TR><TR><TD CLASS="quote">If it's your master, maybe it's leaking thru the firewall, soaking into the padding beneath the carpet.</TD></TR></TABLE>
thats what im thinking it may be, but how would you check from inside the car for leaks. or what is a possible
