What's THIS?!?!
Old Mar 15, 2004 | 04:51 PM
B00ST2nR's Avatar
Default What's THIS?!?!
Ok. Let me make the long story short.
I was installing my Fuel Rail. Had some leak problems. Found out it was a bad O-ring on the Injectors. Went to the dealer, bought new O-rings and replaced them.
No more leak problems from the Injectors, but this time it was leaking from the end. So I thought it was because I didn't tighten it well enough.
Went ahead and tightened it, and SNAP! The end bolt broke. And the cap dropped somewhere and now I can't find it. I'll need to buy a new one, but have no idea what its called and what the Part # is.
Here's a picture of what I'm talkin about. The white end cap I'm talkin about is circled in the picture.
Here's the bolt that snapped.
if anyone knows the part number for the cap that screws on the end of the fuel rail, PLEASE let me know. Thanks.
Old Mar 15, 2004 | 05:05 PM
Sliced Beard's Avatar
Default Re: What's THIS?!?! (Skunk2nR)
when you go to the dealership they should have diagrams of the entire assy.
it should be fairly easy to get the correct part without the part number
Old Mar 15, 2004 | 05:30 PM
Kamin's Avatar
Fuel pressure regulator.
Old Mar 15, 2004 | 05:34 PM
B00ST2nR's Avatar
Default Re: What's THIS?!?! (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">Fuel pressure regulator.</TD></TR></TABLE>
I don't think its the FPR. It's on the opposite side of where the FPR is on the Fuel Rail.
I think it's the Fuel Pulsation Damper. It's a white cap that screws on the end and holds the fuel line to the Fuel Rail.
Old Mar 15, 2004 | 05:40 PM
Kamin's Avatar
OHHH its a GSR motor, hahaha im all ******* backwards.
Old Mar 15, 2004 | 05:50 PM
jdmlsvtec8's Avatar
Do you need this part to run the car?
Can you just put AN fitting that connects to a stainless steel braided hose?
Old Mar 15, 2004 | 06:04 PM
B00ST2nR's Avatar
Default Re: What's THIS?!?! (jdmlsvtec8)
Good News!
I found that biatch. Was browsin around with a flash light, checkin every corner, and I got lucky.
But there's a new problem now. How do I get the broken bolt out? It's twisted in there pretty tight.
Old Mar 16, 2004 | 07:13 AM
Rtype16's Avatar
He is right it is a pulse dampener from the factory. Try holding the pulse dampener in a vice and using vice grips on the bolt to unscrew it.
Old Mar 16, 2004 | 11:00 AM
martini's Avatar
Default Re: What's THIS?!?! (Rtype16)
yeah, it's the FPD, but I don't believe you can buy that seperately from the fuel rail. Worth a shot though, I guess.
Old Mar 16, 2004 | 11:31 AM
onePOINTsix's Avatar
Default Re: What's THIS?!?! (martini)
i hate those things, i'm not sure wtf they do but mine burst and sprayed me with gas (start of MPFI swap ) so i took one off of a Y8 rail
JZiggy
Sep 1, 2009 01:03 PM
Btothe3rdDegree
Sep 19, 2004 07:29 AM
_bB
Jun 7, 2004 07:22 AM
B00ST2nR
Mar 15, 2004 07:02 PM
Leb_CRX
May 23, 2003 06:17 PM
