Oil problem
Old Mar 15, 2004 | 05:29 AM
hondaracing1's Avatar
Default Oil problem
Last night will driving my eg my oil light came on and i knew it was kinda wierd because like a month ago we change the oil and everything and it hasnt been drove but maybe like 3-4 times in that month, but it does have a oil leak but not serious enough to make it lose that much oil. Also i cleaned the vtec sileniod the other day. Do you think that could cause it to do that? maybe i did something wrong, and also before the oil light even came on vtec wasnt engaging. It has oil in it cause we checked it today.
SO does anyone know what it could be?!?!
Old Mar 15, 2004 | 05:49 AM
doublejz's Avatar
Default Re: Oil problem (hondaracing1)
it might not a matter of having low oil, i would check your oil pressure. If it is low it won't allow vtec to engage which would also give you the oil light. Theres not much you can mess up with the solenoid just a sensor and a screen.
Old Mar 15, 2004 | 01:11 PM
Default Re: Oil problem (doublejz)
how do i check oil pressure what could i do to fix this problem
Old Mar 15, 2004 | 03:36 PM
doublejz's Avatar
you could go buy a gauge and see what it says. it may be your pump
Old Mar 16, 2004 | 10:22 AM
im not that good with cars so this question prob wont make since but is there anyway for me to build the pressure back up? and do you think the leak i have could cause the pressure lose?
Old Mar 16, 2004 | 11:09 AM
doublejz's Avatar
your oil pump is what keeps the pressure up, if you do have a bad pump then no theres nothing you can do to build the pressure up. Just buy a cheapo mechanical gauge, remove your pressure switch screw the gauge in there, and see what it tells you. I think it should be like 15-20 at idle and like 75-80 in vtec
Old Mar 16, 2004 | 05:39 PM
my dad thinks my oil pump is cloged up from all the slug i got in the motor. I took the valve cover off and it had nothing but caked up oil all in and under it and he thinks that stuff is clogging the oil pump.
Question now is....Can you take the oil pan off without having to take the engine out of the car? j/w
Old Mar 16, 2004 | 05:53 PM
doublejz's Avatar
im hoping it doesn't look like this
https://honda-tech.com/zerothread?id=667336
Old Mar 16, 2004 | 09:39 PM
yes my friend it looks exactly like that!
Old Mar 17, 2004 | 05:18 AM
Jimmy's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaracing1 &raquo;</TD></TR><TR><TD CLASS="quote">yes my friend it looks exactly like that!</TD></TR></TABLE>
Underneath your valve cover looks like that to?
Old Mar 17, 2004 | 06:47 AM
Default Re: Oil problem (Usdmdc2)
yeah it looks exactly like that or well not that bad now cuz i scraped a lil off of it but not enough to help it and my dad thinks thats why im gettin the oil light cuz i scraped some off and it clogged the oil pump.
edit: but it wasnt my fault it got like that. I guess i should be more careful when buying a car
itzyaboyzeem03
Jul 1, 2016 04:40 PM
JStar
Apr 6, 2006 02:29 PM
integra_94
Aug 31, 2004 09:10 PM
hondaracing1
Mar 15, 2004 01:03 PM
Cashflo
Aug 24, 2003 07:31 PM
