What pistons to use on my ls
Old Oct 19, 2001 | 03:51 AM
integra81's Avatar
New User
Default What pistons to use on my ls
i have an integra ls with 110k. what should i do to the egine?? what type of pistons should i get for all motor?? I want to be almost as fast as a GS-R bt dont want to run a big bill
thanks
Old Oct 19, 2001 | 06:51 AM
Leimokei's Avatar
New User
Default Re: What pistons to use on my ls (integra81)
too get a B18A/B into as fast as a GSR is going to be bank and not recommend, but then again that's your money.....if its all motor route...cai/skunk2 intake manifold/bored throttle body/crower non vtec cams/cam gears/je custom forged pistons/head ported and polish/valve retainers/springs/4-2-1 header/high flow cat/2.5in piping..interior gutted...plus some slicks..also msd ignition...
or you can get build your bottom end...since you got a ls you don't need to do much to boost higher and higher if you get turbo...i've seen people run 13psi on stock internals...and as high as 22psi...quickest way to kill GSR's.....(the oh **** he's got it button...Nitrous) hope that helps
Old Oct 19, 2001 | 06:55 AM
VTEC4GS's Avatar
get the civic Type R and put on the LS rods, rebalance and also get oversized (81.25mm) and get your high mileage block bored.
could always upgrade topend to VTEC later on, do block for now.
Greg
Old Oct 19, 2001 | 02:24 PM
MRXMUFFIN's Avatar
Default Re: What pistons to use on my ls (Leimokei)
hey leimokei its me again, where did u get your forged pistons, do they have a website? and whats your compression with them?
joedr
Nov 30, 2008 01:25 PM
almostjdmeg
Oct 8, 2008 08:33 AM
saleensolution
Mar 22, 2005 01:49 PM
fabs
Mar 13, 2005 12:20 PM
RAWB
Mar 23, 2003 03:51 PM
