just pulled head need help on installing distributor
Old Mar 12, 2004 | 09:41 PM
Ek00fbp's Avatar
Default just pulled head need help on installing distributor
I was told that if I put the distributor on and it is tilted in any direction it can advance or retard my timing, is this true? If so, then how do I put it back on without changing my timing? Also is it possible to have a blown head gasket and the gasket to look fine when inspected?
Old Mar 12, 2004 | 09:56 PM
AMS MIKE's Avatar
Default Re: just pulled head need help on installing distributor (Ek00fbp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ek00fbp &raquo;</TD></TR><TR><TD CLASS="quote">I was told that if I put the distributor on and it is tilted in any direction it can advance or retard my timing, is this true? If so, then how do I put it back on without changing my timing?</TD></TR></TABLE>
WOW...I yet again don't know how to respond to this one.
Why don't you buy a Honda service manual/Helms Manual/Haynes manual
Old Mar 12, 2004 | 10:32 PM
Lscivichatch92's Avatar
Default Re: just pulled head need help on installing distributor (AMS MIKE)
the distributor will fit right into the grooves on the camshaft one way. then u just get a timing light and line up the marks however u want. are you running aftermarket cam gears? did u make sure the number one cylinder was a top dead center b4 pullin the head?
Old Mar 12, 2004 | 11:46 PM
Ek00fbp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AMS MIKE &raquo;</TD></TR><TR><TD CLASS="quote">
Wow, Mike I'm sorry I'm not as skilled as you are. Why don't you stop responding to every single one of my freakin posts if u think my questions are so ridiculous.
Old Mar 12, 2004 | 11:49 PM
Ek00fbp's Avatar
Default Re: just pulled head need help on installing distributor (Lscivichatch92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lscivichatch92 &raquo;</TD></TR><TR><TD CLASS="quote">the distributor will fit right into the grooves on the camshaft one way. then u just get a timing light and line up the marks however u want. are you running aftermarket cam gears? did u make sure the number one cylinder was a top dead center b4 pullin the head?</TD></TR></TABLE>
No I did not set the number one cylinder back to TDC before pulling out the cams. I did notice the groove for the intake cam on the distributor but I was told that if I turn the distributor it will change the timing just wanted to get some info. My cam gears were both set to zero though. So when I put the timing belt back on I just make number one cylinder is at TDC and that both cams are pointing up to 0?
Old Mar 12, 2004 | 11:50 PM
Ek00fbp's Avatar
ya I'll do that right when I get some money. Want to give me some?
Old Mar 13, 2004 | 06:43 AM
IN VTEC's Avatar
Cam timing and ignition timing aren't interchangeably related. You can change the ignition timing by changing the Intake cam timing, but not vice versa.
Set the base distributor timing a little retarded when you go to first start it up. Warm it up and then set the ignition timing with a timing gun. See service manual for details of the procedure. There are a couple of them floating around on-line.
Old Mar 13, 2004 | 08:11 AM
AMS MIKE's Avatar
ya I'll do that right when I get some money. Want to give me some?</TD></TR></TABLE>
Not my problem you ran out of money building a monster car. But seriously, its a very smart investemnt to get a OEM service manual. Every question you have can be answered in the book and it also tells you how to do pretty much everything. Its going to be your best $50 you spend other than C-16
Old Mar 13, 2004 | 08:18 AM
mmuller's Avatar
Mad Scientist
pop quizzz...
whats one of the first things you get when you gonna modify your car and attempt to do work yourself?
1.money....
2.SERVICE MANUAL
and everything else.....
Old Mar 15, 2004 | 10:58 AM
michael O's Avatar
Default Re: just pulled head need help on installing distributor (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">pop quizzz...
1.money....
2.SERVICE MANUAL
and everything else.....</TD></TR></TABLE>
that's how I did it.
Old Mar 15, 2004 | 11:45 AM
dfoxengr's Avatar
get a timing light
prodjay10
11
Mar 28, 2015 09:07 PM
mlong01
Dec 6, 2007 06:36 PM
macfadyen
Jan 23, 2007 03:52 PM
civicracer1993
Nov 8, 2002 09:38 PM
fsp31
Mar 15, 2002 07:36 PM
