LS/vtec yet another problem
Old Mar 12, 2004 | 01:58 PM
SprayinCX's Avatar
Default LS/vtec yet another problem
My vtec will not crossover
i am running a chipped p28 with a ITR program
i have a 94 ls bottom end and 2000 si head plus
all the other stuff that you need.
i have checked wiring and solenoid and swapped ecu's what else could it be?
although i do not have a oil pressure gauge. so that could be one problem.
Old Mar 12, 2004 | 02:26 PM
ultimatehonda's Avatar
Default Re: LS/vtec yet another problem (SprayinCX)
You may want to check your oil pressure, because that has a part with the vtec process. Also are you throwing any CEL's?
Old Mar 12, 2004 | 02:33 PM
SprayinCX's Avatar
Default Re: LS/vtec yet another problem (ultimatehonda)
i am not throwing any CEL's
i don't have a gauge yet but i am getting one from a guy.
Old Mar 12, 2004 | 03:41 PM
SprayinCX's Avatar
up
Old Mar 12, 2004 | 10:32 PM
highcomp's Avatar
I just finnished my LS/Vtec after 3 mounths of troubleshooting the same problem and come to find out my main berrings were bad. Im not saying thats the problem but there are a lot of things you need to check in the very sensative vtec oil system remember thats all it is "oil pressure". Test the oil pressure coming into the head via oil line then test the pressure after the solinoid while the solinoid is "open" shorted. Then make sure the iol passage under the head is seald shut or pluged then let me know from there. Let me guess no CEL if not try to get into the upper rpms around 6k for more than 5 sec to see if you trip CEL for vtec oil press switch if so try new sw. **** I could go on all night withe the testing Ive done on this monstar setup.
Old Mar 12, 2004 | 10:53 PM
simple4012's Avatar
New User
Default Re: LS/vtec yet another problem (highcomp)
what size is the feed going to your head for oil. i bet its to big
Old Mar 13, 2004 | 03:48 AM
SprayinCX's Avatar
Default Re: LS/vtec yet another problem (simple4012)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by simple4012 &raquo;</TD></TR><TR><TD CLASS="quote">what size is the feed going to your head for oil. i bet its to big</TD></TR></TABLE>
4an steel braided line
Old Mar 13, 2004 | 09:06 PM
highcomp's Avatar
if the feed was too big and the pressure was less then requierd you would get CEL 22 on obd1 vtec oil press switch since this is not happening i believe that you oil is not the problem at least to that point its not the prob.
Old Mar 16, 2004 | 12:55 PM
SprayinCX's Avatar
well i am not what i did but it works so thats good.
tobster
Mar 13, 2011 12:32 PM
4door hobo
Jul 30, 2007 07:53 PM
bigislandc2
Sep 2, 2006 10:37 PM
bigmacks
Aug 25, 2005 02:08 PM
highcomp
Feb 9, 2004 12:32 AM
