Break in cams???
Old Mar 11, 2004 | 12:09 PM
C8V6C's Avatar
Default Break in cams???
Do u have to "break in" cams, springs, and retainers?
Skunk 2 stage 2s all the way......
Thanks
Old Mar 11, 2004 | 01:51 PM
notstock93's Avatar
Default Re: Break in cams??? (C8V6C)
Nope. They are a drop in and go install. If you rebuilt the head or something, then yes, but otherwise, no.
Before you romp on the engine, make sure everything is top notch, the car is in tune, ETC.
Old Mar 11, 2004 | 02:00 PM
Rtype16's Avatar
Default Re: Break in cams??? (notstock93)
Make sure everything is okay valve to piston clearance. Valve lash. Let the puppy warm up and away you go.
Old Mar 11, 2004 | 02:42 PM
tmoore's Avatar
Yes, you have to break in CAMS. You have to coat them with prelube and then normally the manufacturer reccommends running the engine at 2000 RPM for 1/2 hour.
Old Mar 11, 2004 | 04:59 PM
krazie1's Avatar
BANNED
Default Re: Break in cams??? (tmoore)
huh
never heard of that expect with regrinds
as I had
but not for long
they suck ***
never seen or heard of any cam needing break in expect the regrind
ever since JG or Bullfrog did that back in the day
Old Mar 11, 2004 | 10:42 PM
C8V6C's Avatar
So just make sure they are tunned, which they will be, let um warm up, and then go?
I can just punch it the first run, as long as it is warm, and everything is coo?
What about a 2 ply Head Gasket? Any break ins?
Old Mar 12, 2004 | 03:13 AM
jdmlsvtec8's Avatar
Which one is it?
Need to break-in the cams or need not break-in the cams?
Old Mar 12, 2004 | 07:05 AM
Rtype16's Avatar
Default Re: Break in cams??? (jdmlsvtec8)
You don't need to break in cams. Just make sure when you install them they have a nice coat of oil all over the cams. Warm it up and go.
Old Mar 12, 2004 | 07:16 AM
dgonzals's Avatar
From: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
learning somethin new today...cool...
Old Mar 19, 2004 | 04:17 AM
Joon525's Avatar
Hmmmmmm, I was asking the same question before and was referred to the following links.
Check out:
http://www.cranecams.com/?show=reasonsForFailure (aimed at domestics, but an engine is an engine!)
http://www.cranecams.com/pdf/214e.pdf
http://www.jimcookperformance.....html
cleanep3
Jun 15, 2010 06:12 AM
ludekid4323
Feb 2, 2009 11:08 AM
JDM_EK4_Coupe
May 15, 2007 06:21 PM
Used2beAb16
May 4, 2004 04:29 PM
CRX A4
10
May 11, 2003 10:52 PM
