Airboxes
Old Feb 22, 2004 | 07:09 PM
BolivianDc2's Avatar
Default Airboxes
After a little thinking and searching i see that a bigger filter is better, but would it matter if it had a wide open space around it?
If you were using an airbox setup like the comptech icebox, would a filter that is a tyte squeeze inside the box have a different affect from using a filter that has some area around it inside the airbox?
Old Feb 22, 2004 | 08:47 PM
carcala's Avatar
Default Re: Airboxes (BolivianDc2)
i would think using a smaller filter that had more area inside the box would have a better affect. that way it can use that space to suck air. when using the larger filter with less area around it i would think it would have a harder time trying to get air almost like suffercating it unless u have some sort of a ram air.
Old Mar 17, 2004 | 08:14 AM
Default Re: Airboxes (carcala)
up from the dead
Old Mar 17, 2004 | 01:37 PM
autoengineer07's Avatar
if you decide to use an airbox my best reccomendation would be to use a panel filter as opposed to a cone shaped one, simply because u do not have to worry about goin nuts over the available area not taken up by the filter. all of the incoming air will pass through the filter, but i would aslo suggest that u plumb an intake tube through the bumper(ram-air).
Old Mar 19, 2004 | 04:47 AM
Default Re: Airboxes (autoengineer07)
makes sense
PeterVSays
Jan 12, 2014 11:22 AM
dpine
Sep 9, 2008 08:29 AM
**DOHC HaTcH**
Feb 14, 2006 06:56 AM
Johnny76
Feb 22, 2004 08:19 PM
Lazydsm
Apr 29, 2003 07:28 AM
