How much with this turbo setup produce B18A1 LS Turbo fully built?
Old Mar 8, 2004 | 10:23 PM
ExplicitSpeed's Avatar
Default How much with this turbo setup produce B18A1 LS Turbo fully built?
I have a 89 crx hf with setup with the following engine and was wondering what kinda power am I in for? I was thinkin 14 psi daily driven? and track psi not sure? any advice? any comments?
Engine, Transmission, Turbo B18A1 engine and transmission T3/T04e turbo 63/70
Bottom
Polished Crank
New rod and main bearings
Crower pro billet rods
Darton open deck sleeves crv sleeves bored .040 over bored to 2.0+L
Arias forged 9-1 pistons, wrist pins, rings
GSR oil pump
New water pump
Aluminum 1 lb. Crank pulley
Balanced
Head
Stage 2 port and polish
Crower valve springs
Crower titanium retainers
OEM keepers
Manley stainless steel valves
Crower stage 2 turbo design split duration cams
AEM cam gears
Skunk2 manifold
70mm TB
LS transmission
ACT 12.5 lb. Flywheel
ACT 6 puck clutch 311 ft lb torque
Phantom grip LSD
Turbo kit
Garrett T3/To4E 63/70 turbo
Custom stainless steel cast manifold
38mm Tial wastegate
Greddy type S bov
2.5” piping
Intercooler 20”x8”x3” core 2.5” inlets
Electronics/Fuel Management
Greddy e-manage system
700cc injectors
MSD BTM kit
Greddy turbo timer
AEM fuel rail
AEM fuel pressure regulator
Autometer gauges boost, oil pressure, water temp., oil temp.
FJO wideband o2 sensor with o2 gauge
Modified by 89crxhfLST at 8:27 PM 3/9/2004
Old Mar 8, 2004 | 10:59 PM
reaction360's Avatar
Default Re: How much with this turbo setup produce B18A1 LS Turbo fully built? (89crxhfLST)
isnt your bottom end also bored n sleeved? and whatever it makes, its still gonna get wooped by my ek...... haha..j/k.... get dat biatch runnin...
theycallmekevin
Feb 1, 2012 06:55 PM
Swipe'd
Sep 1, 2007 04:39 PM
B18 CYA
May 22, 2004 11:22 AM
ExplicitSpeed
Apr 6, 2004 11:30 PM
boostedrs97
Jun 5, 2003 08:07 AM
