which precision turbo? upgraded setup
Old May 5, 2004 | 12:19 PM
B18 CYA's Avatar
Default which precision turbo? upgraded setup
Well, bought a new block and head...bought an sc34 before I bought it so I guess I'll have to sell the SC34 and get a bigger turbo? lemm eknow what u think i should get...heres my setup on a GSR Engine:
Engine:
1.8 VTEC Block
84mm Darton Sleeves
JE 9:1 Pistons
Eagle H Beam Rods
Pro Drive Oil Pump Gear
Cometic Turbo Head Gasket
ARP Head Studs
Ported Head
Crower Valves
Crower Springs
Crower Retainers
Crower Turbo Cams
AEM Cam Gears
AEM Fuel Rail
AEM FPR
GReddy Timing Belt
Skunk2 Manifold Ported
ITR LSD
Centerforce Dual Friction Clutch
Turbo setup:
Inline Pro T3 5 Bolt Stainless Manifold
Precision 31.5 X 8.0 X 3.5 Intercooler
Turbo Xs RFL Blow Off Valve
Tial 38mm Wastegate w/ 1.0 bar Silver
Greddy Black Turbo Timer
Apexi AVCR Boost Controller
Oil Return and Feed kit with flanges and fittings All XRP
Pusher Fans
2.5" stainless intercooler piping
3" Downpipe
Thermal R&D Turbo Exhaust
Precision 780 CC Injectors
Walboro 255LPH Fuel Pump
OBD1 P72 ECU
Planning on tuning with uberdata.
What turbo compressor do you guys recommend? I am hopin for 450 WHP using roughly 22 psi...should I boost more psi? BTW, this will be my daily driver want to spool around 3500 rpm and keep gaining power until redline...
Old May 5, 2004 | 02:02 PM
RyanEJ8's Avatar
Default Re: which precision turbo? upgraded setup (c2nap)
An SC34 should be perfect for you setup. It is rated for 545 crankshaft hp so it should be good to 465whp with a quick spool. You will probably have to run more than 22 psi, but the amount of psi you are boosting is really irrelevant. However, if you want more room to grow from 450whp you may want to go with an SC-60 or SC-61.
Old May 5, 2004 | 03:03 PM
B18 CYA's Avatar
wonder if an sc60 or 61 would cause too much lag :/
Old May 5, 2004 | 04:31 PM
ndogg's Avatar
Default Re: (c2nap)
sc61 sounds better suited. with the 1.9L you should be spoolin pretty good.
Old May 6, 2004 | 01:11 PM
B18 CYA's Avatar
bump
Old May 6, 2004 | 01:24 PM
warwagon's Avatar
Default Re: (c2nap)
get the 61!!!! might as well get it now cuz you will want it later!!!!
Old May 6, 2004 | 01:49 PM
B18 CYA's Avatar
when do u think it will start spooling up and reach full boost at? dont want too much lag
Old May 7, 2004 | 09:55 AM
B18 CYA's Avatar
sc60 or sc61 ? i want sumthin that reaches full boost at around 5000 rpms.... 25 psi...and i want a compressor that has room for more expansion whenever i go to the dyno...
Old May 7, 2004 | 10:09 AM
RobbieG35's Avatar
12 Years Strong
Default Re: (c2nap)
SC61! It has good spool time and can provide more than enough power
Modified by HybridHatch88 at 7:20 PM 5/7/2004
Old May 7, 2004 | 10:25 AM
G
sh!t happens.
Default Re: (HybridHatch88)
the sc34 or the sc61
Old May 7, 2004 | 10:49 AM
Acura_I-RS's Avatar
Default Re: (G"UNIT)
INNOVATIVE GT61S gets my vote man, wonderfull turbo, contact spark racing for more info and prices,
Old May 7, 2004 | 07:36 PM
B18 CYA's Avatar
hmm anyone else?
Old May 9, 2004 | 09:50 AM
B18 CYA's Avatar
bump...anyone else can put their input?
Old May 9, 2004 | 09:51 AM
B18 CYA's Avatar
err double post
Old May 22, 2004 | 11:22 AM
MrBond's Avatar
when did your SC34 spool?
How much boost does it make around 3800rpm?
*curious*
Im having a hard time chosing for my engine too, I want something that spools pretty good by 4k rpm. Thinking SC34, SC44 or SC60... Dont know how different they really would be...
MrBond.
Jake92eg
Apr 26, 2006 07:55 PM
B18Sleeper
Sep 24, 2005 11:02 AM
M.A.R.C.
Jul 11, 2004 02:57 PM
ExplicitSpeed
Mar 8, 2004 10:59 PM
boostedrs97
Jun 5, 2003 08:07 AM
