issues w/ removing ac?
Old Mar 6, 2004 | 11:46 PM
NoLipRacen's Avatar
Default issues w/ removing ac?
ive got the whole system dissconnect except for the compressor and im really confused with this belt. the alternator and compressor share the same belt and if i take out the compressor then i will lose tension. do i need to go buy another belt? or what? im so confused and its so late someone please help me! thanks!
Old Mar 6, 2004 | 11:59 PM
sharkcohen's Avatar
Default Re: issues w/ removing ac? (NoLipRacen)
Yes, you will need a shorter belt.
Old Mar 7, 2004 | 03:59 AM
Aaron.Hillman's Avatar
I'm not shure but is a 36.5in belt. The belt catalog in Auto Parts tells the part no. w/o a/c.
Old Mar 7, 2004 | 08:39 AM
JDMBB2's Avatar
Default Re: issues w/ removing ac? (aahill69)
i recently removed a/c and i just went up to autozone and they had a belt in stock because a/c was an option so they make belts with no a/c
Old Mar 7, 2004 | 09:33 AM
mattmw88's Avatar
Default Re: issues w/ removing ac? (jdmh22lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmh22lude &raquo;</TD></TR><TR><TD CLASS="quote"> a/c was an option so they make belts with no a/c</TD></TR></TABLE>
Are you sure about that? I have a prelude S and mine had it. In addition I've never heard of anyone not having it in a lude. I might be wrong though... I do agree with needing a new belt though, mine is from an accord of some sort, and is one rib too short.
Old Mar 7, 2004 | 01:15 PM
donz's Avatar
Default Re: issues w/ removing ac? (mattmw88)
there is a belt for no a/c... 100% sure
Old Mar 7, 2004 | 06:58 PM
JDMBB2's Avatar
Default Re: issues w/ removing ac? (donz)
well i just figured it was an option because when i bought mine i said 92 prelude belt w/no a/c and no questions asked but i am also 100% sure they make a belt that will fit
Old Mar 8, 2004 | 02:11 PM
mattmw88's Avatar
does anyone know what type of belt this is? I notice a crack, which is normal, but I want to be ready to switch it when needed. Thanks guys..
Old Mar 8, 2004 | 06:36 PM
Hit N' Low lude's Avatar
a/c was an option with some preludes, but to avoid any question of length just measure around the alternator pulley and the crank pulleywith a string or something. there are belts available in almost any size at most part stores.
Old Mar 13, 2004 | 01:01 AM
NoLipRacen's Avatar
Default Re: issues w/ removing ac? (Hit N' Low lude)
ive been looking around online but i cant find one for the vtecs...
19crx93
22
Aug 16, 2010 03:46 PM
hpsi93
Aug 26, 2007 02:47 AM
SamC
Feb 13, 2006 08:39 AM
oxSLEEPERxo
Mar 20, 2005 11:23 AM
srv3fender
Mar 1, 2005 05:18 AM
