how to get rid of your a/c?
so i am cleaning up the bay and am getting rid of the criuse control and my a/c. i was wondering what all i shouls take off? and am i going to need another shorter belt?? thanks in advance.
Re: how to get rid of your a/c?
If you don't have PS, then you only need one belt (alternator). They are both serpentine (alt and ac). Take EVERYTHING that has to do with the AC out. That includes the compressor, belt, ac lines, any wiring.. anything ac related really.
i live in colorado a lil place called vail. no need for a/c kinda... but yeah all done are these parts worth any money and all the hoses are messed up but have everything eles.came out really good. thanks guys!
A serpentine belt is a single belt that will go on one pulley on the motor and run multiple things. The B and D series motors have grooved belts that are similar in appearance, but they only run one item each. Fortunately, this makes removing features easier than needing shorter belts or idlers for deletes.
Just make sure you empty you freon first. I took out my AC with a full charge and when I unscrewed a line I created a huge freon cloud which was pretty funny. **** went everywhere.
Pics of the engin without a/c.http://i842.photobucket.com/albums/z...treras/002.jpg
Your crazy... do you really want to get rid of your a/c when you have a stock single cam? If you have something crazy like a built track motor than I would suggest removing the a/c belt. I have a semi built h2b motor and I WISHED I had a/c, power steering, and cruise control..
So you have no PS, took out AC and Cruise right? That's pretty much all thats "removable". To clean it up some more, I drilled out the spot welds that held the brackets that held the AC condensor in place and removed the brackets. You could do a simple wire tuck of the harness that runs along the shock towers (headlight/horn/ ect harness) and run it in the fenders. Just seach wire tuck for some help. Get some Simple Green and a scrub brush and scrub the bay to get the grime off, touch up spots with paint if you have a easily matchable color and you should have a really clean bay, I know mine is lol
oxSLEEPERxo
03-20-2005 11:23 AM
EGcivicBoy
11-11-2003 05:21 PM
