J&S ultra Safeguard version 2 or inline pro headgasket
Old Oct 16, 2001 | 10:34 AM
teamrocket si's Avatar
Default J&S ultra Safeguard version 2 or inline pro headgasket
Which would help me run the safest and highest amount of boost on a basic drag kit J&S Ultra Safeguard version 2 or the inlinepro lower compression head gasket?
Old Oct 16, 2001 | 10:38 AM
boomslang's Avatar
Default Re: J&S ultra Safeguard version 2 or inline pro headgasket (teamrocket si)
Not the safeguard.
Old Oct 16, 2001 | 10:49 AM
GGrahnVI's Avatar
New User
Niether. There is no substitute for good tuning.
Old Oct 16, 2001 | 11:25 AM
jinxproof99's Avatar
New User
Default Re: J&S ultra Safeguard version 2 or inline pro headgasket (GGrahnVI)
whatever you say jackass.
Old Oct 16, 2001 | 11:59 AM
Adi Radoncic's Avatar
On Fire!
Default Re: J&S ultra Safeguard version 2 or inline pro headgasket (jinxproof99)
If you plan on running stock internals put the two of them together because the more boost you run the margin of error gets slimmer and in that part J&S would help with keeping your motor from detonating and the inline pro would give you lower compression to take higher boost levels.
Just my 0.2 cents...
Old Oct 16, 2001 | 12:05 PM
ZygSpeed's Avatar
Default Re: J&S ultra Safeguard version 2 or inline pro headgasket (newgsr)
the way I see it, ... just like NEWGSR said!!
Old Oct 16, 2001 | 12:27 PM
DragII's Avatar
25 Year Member
Default Re: J&S ultra Safeguard version 2 or inline pro headgasket (zygspeed)
if you are running low boost levels, the J&S will be fine....I like the Inlinepro gasket, it's a great product...but there is no need to lower your compression that much @7 or 8psi.
golf-mk3
Feb 22, 2010 07:00 AM
D1andOnly
Nov 27, 2005 05:00 PM
PePpeRedDc5
May 22, 2005 09:36 AM
RooskiGSR
Feb 28, 2005 04:23 PM
sunny79
Oct 20, 2002 02:58 PM
