J&S ultra Safeguard version 2 or inline pro headgasket
Which would help me run the safest and highest amount of boost on a basic drag kit J&S Ultra Safeguard version 2 or the inlinepro lower compression head gasket?
Re: J&S ultra Safeguard version 2 or inline pro headgasket (jinxproof99)
If you plan on running stock internals put the two of them together because the more boost you run the margin of error gets slimmer and in that part J&S would help with keeping your motor from detonating and the inline pro would give you lower compression to take higher boost levels.
Just my 0.2 cents...
Re: J&S ultra Safeguard version 2 or inline pro headgasket (zygspeed)
if you are running low boost levels, the J&S will be fine....I like the Inlinepro gasket, it's a great product...but there is no need to lower your compression that much @7 or 8psi.
RooskiGSR
02-28-2005 04:23 PM
sunny79
10-20-2002 02:58 PM
