Cam shafts
Old Mar 3, 2004 | 05:16 PM
93civic_sedan's Avatar
Default Cam shafts
Ok just got the car in my sig. I want to build the valve train, I hear that ITR cam shafts are good, but not as good as like skunk 2 stage2. I don't have alot of money, has anybody ever herd anything about "web cams"? What are some affordabel options?
Old Mar 3, 2004 | 05:55 PM
DC2*Integra's Avatar
Default Re: Cam shafts (93civic_sedan)
if you dont have a lot of money, go for the type r cams. You can find them in the classified section used for about 300 and up.
Old Mar 3, 2004 | 06:01 PM
But I want to make power will they help alot?
Old Mar 3, 2004 | 06:04 PM
Chemicalviper's Avatar
You get what you pay for, web cams and zex cams are junk, dont believe me ? - search it unde team integra i think, the zex cams actually lost power over stock gsr from 4300+ rpm.
ITR cams are not agressive as skunk stage 2, and not even as agressive as stage 1 - w/ stage 2 you need to tune and get bigger injectors. You need to search more.
Old Mar 3, 2004 | 06:16 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: Cam shafts (Chemicalviper)
Yup, listen to what Chemicalviper said. Search more as well.
It all depends on how much money you want to spend and what are the power goals of your car.
Old Mar 3, 2004 | 06:17 PM
turbotommy's Avatar
save save save
Old Mar 3, 2004 | 06:20 PM
crawdad689's Avatar
Default Re: Cam shafts (turbotommy)
consider your long range goals
if turbo is in your future-------->itr/ctr
if you're makin an all motor beaster-------->skunk2 stage2
if you go stage2, you're gonna wanna replace valve springs and retainers too. the whole thing's gonna cost you well over a G (that's not including installation if you don't do it yourself)
stage2 cams on a forced induction setup ain't kosher
just get some ctrs and call it a day
Old Mar 3, 2004 | 07:23 PM
Kendall's Avatar
You really need to consider the fact that on an otherwise stock engine, certain cams will not perform as they are designed to. The largest cams I would run on a stock B16 are the CTR cams, anything beyond that will hurt certain aspects of performance. Compression has a lot to do with your cam decision. Also, you should consider whether you want more power up top, or in the middle. Cams are probably the most complex of engine components. Don't buy any without understanding exactly what you need to look for to accomplish your goals.
Old Mar 3, 2004 | 07:29 PM
fuck honda-tech's Avatar
Default Re: (Kendall)
:cough: ctr exhaust cam jun 2 intake cam :cough:
Old Mar 3, 2004 | 07:54 PM
b00sted4dr's Avatar
Default Re: (epsom salt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by epsom salt &raquo;</TD></TR><TR><TD CLASS="quote">:cough: ctr exhaust cam jun 2 intake cam :cough: </TD></TR></TABLE>
Isn't the jun 2 intake cam alone like $500.
If you get something aggresive as skunk stage 2's your gonna valvetrain also which is gonna cost some $$$. I believe it is safe for itr/ctr cams with stock valvetrain, as some people run it.
It comes down to how much power you want to make and how much your willing to spend.
Old Mar 3, 2004 | 08:04 PM
b18c1995's Avatar
jun2 intake and ctr/itr exhaust cam combo is a great power maker under 8200 and while not requiring huge compression ratios. If you do the math you will end up spending about 750 on that setup, and about 750-800 on a set of skunk2 stage 2s.
Old Mar 4, 2004 | 04:45 PM
Default Re: (b18c1995)
So what you guys think about CTR cams and AEM cam gears? Is the install that hard? Thanks for all the posts so far...keep 'em commin guys
Old Mar 4, 2004 | 08:37 PM
Default Re: (93civic_sedan)
install is kinda hard if your not familiar with valve adjustments etc. i would have a shop put them in also, search man... i hear aem cam gears are trash...
Old Mar 4, 2004 | 08:48 PM
LSTEG96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by epsom salt &raquo;</TD></TR><TR><TD CLASS="quote">install is kinda hard if your not familiar with valve adjustments etc. i would have a shop put them in also, search man... i hear aem cam gears are trash...</TD></TR></TABLE>
please be kidding?!
Old Mar 4, 2004 | 09:09 PM
TopEnd's Avatar
Default Re: (LSTEG96)
Yea AEM cam gears are great, the cams are a little complicated to install, but the gears are now that hard, just do some searches and u could probably do it.
- You have to be careful tho
Old Mar 4, 2004 | 09:19 PM
[ iLL ] iNt3GrA's Avatar
i dont think that epsom salt was putting in a good word for the AEM cams lol epsom salt what cam gears would you recommend over the AEM's?
Old Mar 4, 2004 | 10:10 PM
Default Re: ([ iLL ] iNt3GrA)
kidding i am not, although i have not used the cam gears, myself, i do know how to use the search engine, and based on my findings I have found many other cam gears that would be a better choice but thats just my opinion.. i am trying to help you out not sabotage the company heres some evidance to back it up: hope this helps
https://honda-tech.com/zerothread?id=406272
https://honda-tech.com/zerothread?id=367132
https://honda-tech.com/zerothread?id=313806
https://honda-tech.com/zerothread?id=246986
https://honda-tech.com/zerothread?id=157828
I hear skunk2 are nice, toda, srr version 2 (150 shipped from perpetualconcepts.com) basically any four bolt cam gear is a good choice! i also know that tweakmeister ( or tweakmiester) sells nice cam gears on his site.
Old Mar 4, 2004 | 10:38 PM
b00sted4dr's Avatar
I've used aem cam gears before (about a year) and they were fine with me. The only thing is if you have the old ones with the allen screws you should get the newer bolts they use, hex. I think i got it for 1 dollar for each, so 6 bucks altogether.
Old Mar 4, 2004 | 11:41 PM
alfaaay's Avatar
Default Re: (96gsr4dr)
'01 ITR or CTR cams will be a good addition to your engine. Like a few people have said, more aggressive cams call for more compression (usually achieved through pistons and other things), and a valvetrain upgrade, which will both run you more $$$. If you have the patience to wait around for the good deals though, they'll come. Either way, research is your friend.
Old Mar 5, 2004 | 12:06 AM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
the install is not hard at all. i did it in 3 hours (normal time) having never opened up my head before. http://www.c-speedracing.com owns you all.
unless you plan on upgrading the valvetrain as well, just stick with ITR.
also, it's not really worth it to buy cam gears for ITR cams. it's not that much of a difference, because with the cam gears requires tuning, which is more money.
and AEM gears only have 3 bolts. people don't trust that as much.
Jeanious
Oct 2, 2007 09:25 PM
DC4R27
Apr 27, 2007 01:54 PM
codeh22a4
Mar 28, 2005 12:37 PM
russian_racer
Jun 6, 2003 01:26 AM
simple4012
May 8, 2002 03:38 PM
