**What are good cams that go with a supercharger!?**
I know there are turbo cams out there but are there any cams out for a supercharger...or...will a stage 2 or 3 yeild good power increase?
(cams for supercharged LS and B16a--for a daily driver!!) Thanx!
Re: **What are good cams that go with a supercharger!?** (russian_racer)
You definately don't want to run a stage 2 or even a stage 1 cam. If you don't have any way to dyno tune, then stick with your stock cam. You want to use a turbo cam that has high lift, short duration. If there is too much overlap, like cams designed for NA motors, then your boost will go right out the exhaust and you will loose power.
Re: **What are good cams that go with a supercharger!?** (fxrob)
find something with a good lobe separation angle (less overlap) and long duration. not sure there is anything available for vtec motors for this ... i would say stick with stock and some adjustable cam gears and wait and see if anyone makes a se tof blower cams for the B series vtec motors.
White S2k
12-01-2002 06:35 AM
