Installing springs/retainers w/out pulling the head?
Old Mar 2, 2004 | 02:29 PM
slooogsr's Avatar
Default Installing springs/retainers w/out pulling the head?
Sorry for being such a nooB question but i just picked up a set of itr springs/retainers and looking in the shop manual it is showing the installation process with the head off. Is it possible to install them w/out yankin the head off??
btw: i did a search and i apologize for the ignorant question
Old Mar 2, 2004 | 03:16 PM
slooogsr's Avatar
uppp
Old Mar 2, 2004 | 04:34 PM
Rocket's Avatar
Default Re: (slooogsr)
You'll want this tool and a hose to pressurize the chamber to keep the valves up.
$77.77 from http://www.thetoolwarehouse.net
This is the actual page. http://www.thetoolwarehouse.net/shop/SP-91400.html
Make sur you plug the oil return holes in the head so the retainers don't drop into your block/oil pan.
ITR springs and retainers only give you 0.5mm more lift capability with but not much more pressure. So you still should limit your rpm's close to stock limits.
Old Mar 2, 2004 | 05:13 PM
virginia_dude's Avatar
Default Re: (Rocket)
WORD--------- Rocket knows what he is talking about. I did ZC valve seals & cams without taking heads off. Will be doing Seals, springs and cams on a B16 as soon as I get mine in from Rocket.
Old Mar 2, 2004 | 05:24 PM
Mike@CCT's Avatar
Formerly Mike@TSR
Default Re: (virginia_dude)
We use a compression check tool to fill the cylinders with air then use the Valve spring compressor. almost as easy as with the head off
Old Mar 2, 2004 | 05:32 PM
DEMNTD1's Avatar
Default Re: Installing springs/retainers w/out pulling the head? (slooogsr)
Be careful not to drop the retainers into the head. It may fall down to the oilpan through the holes on the head.
Old Mar 2, 2004 | 06:16 PM
JSPEED's Avatar
Default Re: Installing springs/retainers w/out pulling the head? (DEMNTD1)
When I do this WITHOUT access to air, I use a couple of shoestrings tied together. Put the piston at BDC and insert the shoestrings, tie the end somewhere so the whole piece doesn't accidently fall in the cylinder. Slowly bring the piston up to TDC for that cylinder until you feel the pressure of the strings against the valves, filling the cylinder between the valves and piston, and you are good to go. I'd be careful with the tool that Rocket suggested, I had a Snap-On and broke the the pivot arm so now I use one that I made. My .02
Old Mar 2, 2004 | 08:01 PM
robtec's Avatar
Default Re: Installing springs/retainers w/out pulling the head? (JSPEED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket &raquo;</TD></TR><TR><TD CLASS="quote">You'll want this tool and a hose to pressurize the chamber to keep the valves up.
ITR springs and retainers only give you 0.5mm more lift capability with but not much more pressure. So you still should limit your rpm's close to stock limits.</TD></TR></TABLE>
any pics showing this stuff at work??
Old Mar 2, 2004 | 08:24 PM
slooogsr's Avatar
excellent, thanx for the information. ok i have one more question though, would it be a better idea to just leave in the stock gsr springs/retainers, and just install my 00'itr cams? obviously i would still keep the rev-limit stock, and from what i hear the itr cams stop pulling near 8.2k anyways.........
the whole reason i ask about installing the springs/ret, is the fact that i bought them as a package deal with the itr cams.......... maybe i will just sell the spring/ret set.
Old Mar 3, 2004 | 06:05 AM
slooogsr's Avatar
up for my 2nd question
Old Mar 3, 2004 | 06:13 AM
VtecKiDD's Avatar
you can run itr cams on stock gsr valvetrain from what i understand an gather. i ran skunk2 stage ones cams which are more agressive on my stock valvetrain fine. just throw those cams in there, an dont worry about the valvetrain since your not going over redline or stock limits anyway.
Old Mar 3, 2004 | 06:57 AM
CHEETAH's Avatar
yeah i do it all the time with the snap on tool. it's easy and jsut use a strong magnet to pickup retinaers.
if oyu're going with ITR or CTR cams, just add inner springs to the exhause side of your head, no need to be upgrading to ITR springs/retainer.
greg
Old Mar 3, 2004 | 08:14 AM
slooogsr's Avatar
ok soo all in all if i dont rev over stock limits i will be just fine without installing the springs......
if i have the time/money i may do as cheetah says and just add the inner springs to the exhaust side........ thanx for you help guys and any more opinions would be great!
Old Mar 4, 2004 | 08:39 PM
smokey2.0's Avatar
there's some good info being shared here, but one thing hasn't been covered: how or what do you do to seal the oil passages on the head? how do you plug these holes up? what do you use?
Old Mar 4, 2004 | 09:41 PM
Ti3d in's Avatar
Default Re: Installing springs/retainers w/out pulling the head? (smokey2.0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokey2.0 &raquo;</TD></TR><TR><TD CLASS="quote">there's some good info being shared here, but one thing hasn't been covered: how or what do you do to seal the oil passages on the head? how do you plug these holes up? what do you use?</TD></TR></TABLE>
Just plug them up with some towels or something. It doesn't matter as long as nothing falles down the passages.
Old Mar 5, 2004 | 05:16 AM
6ghatch's Avatar
Default Re: Installing springs/retainers w/out pulling the head? (CHEETAH)
Which snap on tool do you use?
or
Old Mar 5, 2004 | 06:11 AM
Mike@CCT's Avatar
Formerly Mike@TSR
Default Re: Installing springs/retainers w/out pulling the head? (6ghatch)
The bottom one
Old Mar 5, 2004 | 06:53 AM
slooogsr's Avatar
thanx for this info guys.......
up for anymore input would be sweet........
cls55boost
Jul 23, 2007 03:20 PM
GapxGuy
Dec 11, 2002 06:35 AM
accordfreak
Dec 10, 2002 03:46 PM
StinkyTofu
Feb 15, 2002 05:46 AM
forksports
Dec 4, 2001 10:10 AM
