What is the WEAKEST part of the engine HEAD??
Old Dec 10, 2002 | 11:56 AM
accordfreak's Avatar
Default What is the WEAKEST part of the engine HEAD??
okay so probably the weakest part of the block is the rings i'm guessing...so.... Right now i'm just gathering information on a build up for my car for my turbo and was wondering what is the weakest part of the head? I just want to upgrade the weakest parts of the head just for my insurance... just in case..
Old Dec 10, 2002 | 12:00 PM
b18bturbo's Avatar
Default Re: What is the WEAKEST part of the engine HEAD?? (accordfreak)
valve springs. they tend to float. the gsr are littler better and the type R are pretty strong as well. But most of them tend to foat.
Old Dec 10, 2002 | 12:04 PM
ninesecrx's Avatar
Default Re: What is the WEAKEST part of the engine HEAD?? (b18bturbo)
but you should do the retainers as well. They kinda suck and if you break on of those, the valve will drop and you just killed the head and the block.
Old Dec 10, 2002 | 12:55 PM
Default Re: What is the WEAKEST part of the engine HEAD?? (ninesecrx)
thanks! i'll be putting down springs and retainers on my shopping list.
Old Dec 10, 2002 | 02:06 PM
TeStUdO's Avatar
if you are gonna do that why not go all out and get forged oversized valves too?
Old Dec 10, 2002 | 03:46 PM
AlphaKennyWun's Avatar
Default Re: What is the WEAKEST part of the engine HEAD?? (00si5)
because cost of springs and retainers
dont not equal
removing the head, sending it off to a machine shop to install valves, having the head re-surfaced, buying a new headgasket, re-attaching the head, re-tuning, and the cost of the valves.
oh yea but the weakest part is definately the springs and retainers. I had valve float, the valve smacked a piston, cracked a retainer and dropped in the cylinder all in that order in a split second. good bye motor.
Many miles later I experienced bent and burnt valves but the car ran for thousands of miles this way so i was able to fix that without losing the whole motor.
springs and retainers are definately weaker than the valves.
[Modified by SO3Burner, 7:55 PM 12/10/2002]
drewhall07
Apr 4, 2011 08:23 AM
chrisk
10
Jun 5, 2003 06:04 PM
WickidSi
Mar 2, 2003 09:42 AM
civicracer1993
Dec 19, 2002 06:31 PM
forksports
Dec 4, 2001 10:10 AM
