Oil Pressure gauge install?!?!?!?! HELP!!!!
Old Mar 1, 2004 | 10:13 PM
SpoolinEK9's Avatar
From: Seattle/Ligonier, WA/PA, United States of Honda
Default Oil Pressure gauge install?!?!?!?! HELP!!!!
does anyone have a tutorial or can you tell me how to install an autometer oil pressure gauge on a d16y7!!! of so please reply or pm me!!!! thanks <3 love!!
Old Mar 1, 2004 | 10:43 PM
mmuller's Avatar
Mad Scientist
Default Re: Oil Pressure gauge install?!?!?!?! HELP!!!! (phaeded)
SEARCH
I did a search and found 40 threads about this only in tech forum...
https://honda-tech.com/zerothread?id=720077
https://honda-tech.com/zerothread?id=683316
https://honda-tech.com/zerothread?id=646016
https://honda-tech.com/zerothread?id=568622
https://honda-tech.com/zerothread?id=504145
and there is many more.
Im not a big fan of tee'ing of the block, run a line from the stock oil pressure sensor loc. into a oil distribution block and go from there.
Old Mar 17, 2004 | 08:30 PM
alfee's Avatar
Default Re: Yo <----
ok i need help on this too.. did some search... but not that clear to me... DIAGRAMS = key.. anyhow, i hear a lot about T'ing off the oil sensor... but how do i do that when i already T'd it for my oil feed line? do i throw another T in there? oh yeah, i got one of'm cheap autometer oil gauges also..
Old Mar 17, 2004 | 10:39 PM
mmuller's Avatar
Mad Scientist
Default Re: Yo <---- (alfee)
Got all the parts at McMaster-carr
https://honda-tech.com/zerothread?id=718486
Old Mar 18, 2004 | 08:22 AM
Bnjmn's Avatar
Default Re: Oil Pressure gauge install?!?!?!?! HELP!!!! (SpoolinEK9)
If it is an electric gauge you need to make sure that the sender is grounded to the car.
Ben
Old Mar 18, 2004 | 08:47 AM
alfee's Avatar
Default Re: Oil Pressure gauge install?!?!?!?! HELP!!!! (Bnjmn)
ok good pic, but that looks like the oil feed line with the oil gauge line connected to it???
the oil feed goes from turbo to block/oil sensor T.. how does that go to what this pic shows? is there 2 T's????
Old Mar 18, 2004 | 10:29 AM
doublejz's Avatar
Default Re: Oil Pressure gauge install?!?!?!?! HELP!!!! (alfee)
mcmaster has stainless steel crosses they, are pricey but very good I did mine in all ss
Old Mar 18, 2004 | 11:55 PM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alfee &raquo;</TD></TR><TR><TD CLASS="quote">ok good pic, but that looks like the oil feed line with the oil gauge line connected to it???
the oil feed goes from turbo to block/oil sensor T.. how does that go to what this pic shows? is there 2 T's????</TD></TR></TABLE>
Just one tee, took the stock oil press. switch out and just run a line from the stock oil press. to the tee.
Old Mar 19, 2004 | 08:40 AM
Crazydave's Avatar
Default Re: Oil Pressure gauge install?!?!?!?! HELP!!!! (mmuller)
Make sure that you are using a BSPT theads for the oil line coming off the Block
NPT is a different pitch of threads...
you will neeed a BSP or BSPT to NPT Adapter or if you can find it BSPT to -AN adapter
NPT is the standard for most sending units..
make sure to ground the sender too..
otherwise it wont work
Old Mar 19, 2004 | 09:32 AM
colt45.5's Avatar
Default Re: Oil Pressure gauge install?!?!?!?! HELP!!!! (Crazydave)
http://www.theoldone.com
Theres detailed instructions there.
DONT USE BRASS fittings when you can buy better steel ones for nearly the same cost.
DONT HANG SENDER ON BLOCK if its electrical
and i DO suggest getting an electrical gauge. Im just not fond of wendys straw holding the fate of my engine. breaks, and boom super soaker oil slick and no bearings by the time the light comes on if you are preoccupied not paying attention at all times. Or squirts all over you from the pillar. Its not a tractor, so why run oil into the car for some go go gadget gauge. Just IMO.
Good luck.
supermansdx
Sep 27, 2009 07:16 AM
JDM_COUPE94
Mar 1, 2007 06:20 PM
ZXRider
Sep 11, 2006 11:49 PM
D17 MoNsTeR
Jun 11, 2003 11:57 AM
Proper
May 4, 2003 02:25 AM
