0.025 gap for spark plug for a turbocharged car?
Old Oct 15, 2001 | 08:13 AM
Lei Siew Long's Avatar
Default 0.025 gap for spark plug for a turbocharged car?
when i start my car it hesitates and is about to stall out so everytime i start it up i have to assist the engine by pressing on the throttle. i was told to gap it at that from a shop and was wondering if this is the correct gap. thanks in adv
Old Oct 15, 2001 | 09:26 AM
TurboTypeR98's Avatar
New User
Default Re: 0.025 gap for spark plug for a turbocharged car? (boostedeg6)
Do you have the stock ignition? When I had the stock ignition I ran a .028 gap(no problems), but if you have an ignition you should be able to run a larger gap....not really sure what that gap should be though...
Old Oct 15, 2001 | 08:59 PM
Default Re: 0.025 gap for spark plug for a turbocharged car? (TurboTypeR98)
no, i have a msd 6al with blaster 2 external coil. it wants to stall out when i first start the car in the am since running this gap.
Old Oct 15, 2001 | 09:00 PM
dustin's Avatar
I run .032 with NGK BKR7E plugs with no issues.
Dustin
Old Oct 15, 2001 | 09:38 PM
KekeK-18's Avatar
Default Re: 0.025 gap for spark plug for a turbocharged car? (dustin)
so you got that problem after you gap it at 0.025? why don't you try to gap it back to .032 and see what happen...
Old Oct 16, 2001 | 07:00 AM
Default Re: 0.025 gap for spark plug for a turbocharged car? (b18cturbo)
yeah, i'm going to do that this weekend since i'm busy during the weekdays. but, it might be that or the timing because i was having problems with the timing and now it is set at 16 for the ignition timing. don't know which one it is but i'll narrow it down the problem this weekend.
Old Oct 16, 2001 | 07:40 PM
Incognito's Avatar
I run .028 gap on stock ignition and wires. No problems.
sflemon
Jul 9, 2010 04:04 AM
zCivic
Jun 22, 2006 02:06 PM
Iceman05
Jan 5, 2006 10:52 AM
hondaeg8
Dec 8, 2004 08:18 PM
skrewdlude
Nov 3, 2003 09:00 AM
