spark plug gap with msd
whats a good gap to set my spark plugs at when using an msd sci ignition kit?
i will be using the ngk spark plugs on a jdm gsr motor.
All Motor Mentor
1 Post
Re: (hondaeg8)
you typically want to run a smaller gap if you're running boost or nitrous often. This makes it easier to ignite the plug and the mixture which is harder to ignite when it's compressed. A larger gap on a NA motor will give you more power and better gas mileage, but it's normally limited by the weak stock ignition as to how wide you can go. Running a MSD will allow you to increase the gap.
