Necessity of Aftermarket Ignition??
Old Jan 4, 2006 | 09:32 PM
Iceman05's Avatar
Default Necessity of Aftermarket Ignition??
So here's my situation: about a year and a half ago I installed a Crane Cams Hi-6 ignition along with the LX-92 race coil. My problem now is that I must re-gap my spark plugs every 1,000 miles or so due to the erosion caused by the more intense spark. If i do not constantly regap them, the ignition breaks up at high rpm/high boost levels (>5000rpms and/or >8psi). It wasn't like that before I added the Hi-6. I also get no radio reception due to the electrical noise put out by the ignition. My question is am I better off replacing the stock ignition and losing the Hi-6 or continuing to regap these plugs? Just FYI, i run NGK 7-series (2 steps colder) plugs on a D16Y8 at .030 gap and ~10psi. Ive heard stock honda ignitions are good to 400+HP, is this true? Thanks in advance for the help!
Old Jan 5, 2006 | 06:02 AM
Iceman05's Avatar
anyone?
Old Jan 5, 2006 | 06:53 AM
PRELUDE-GT35R's Avatar
Default Re: Necessity of Aftermarket Ignition?? (Iceman05)
Go to a honda dealer and buy the stock Ignition and put them back on. See it would help.
Old Jan 5, 2006 | 07:09 AM
Adi Radoncic's Avatar
On Fire!
Try a lower gap .022-.024, .030 is way big for that ignition..
Old Jan 5, 2006 | 07:12 AM
beepy's Avatar
Default Re: Necessity of Aftermarket Ignition?? (Adi Radoncic)
Try using a spark plug with a steel electrode, like the NGK V-power. I found that copper electrode plugs only lasted a couple thousand miles on my car, too.
Old Jan 5, 2006 | 07:49 AM
mike1114's Avatar
Default Re: Necessity of Aftermarket Ignition?? (beepy)
Since you posted in FI I assume you have turbo setup.
What is your engine management.
You should ditch the ignition setup. Stock is good up for around 500 whp.
I'm pushing 400whp daily driven on completely stock ignition with hondata management.
Old Jan 5, 2006 | 09:43 AM
TurboEM1's Avatar
Default Re: Necessity of Aftermarket Ignition?? (mike1114)
i have seen stock honda ignitions on 600+ hp cars. go back to stock.
Old Jan 5, 2006 | 10:52 AM
Iceman05's Avatar
I put the stock back on, it started right up and seems to rev faster. I'm going to keep it stock- we all know the saying- K.I.S.S.
dantamparacer
Jun 28, 2012 03:46 AM
smashsmashdance
Jul 18, 2007 05:51 PM
hondaeg8
10
Feb 4, 2005 04:37 PM
Dokta
Jan 23, 2002 05:39 PM
Duck Sauce
Jan 13, 2002 06:17 PM
