greddy 18g turbo how much power can it support? (searched already)
Old Feb 28, 2004 | 08:52 AM
swoosh's Avatar
Default greddy 18g turbo how much power can it support? (searched already)
Does anyone know how much power can be pulled from the greddy 18g turbo from the 99-00 civic si kit. Can I get 300+whp from it? Any info will be greatly appreciated.
-swoosh
Old Feb 28, 2004 | 09:07 AM
TurboJesse
Guest
Posts: n/a
Default Re: greddy 18g turbo how much power can it support? (swoosh)
yes it will do 300.
Old Feb 28, 2004 | 09:12 AM
swoosh's Avatar
Default Re: greddy 18g turbo how much power can it support? (Mpir3)
I have a built bottom end with 9:1 cr on a b16 will that turbo give my 320 at the wheels, I want to run 17 psi.
-swoosh
Old Feb 28, 2004 | 11:15 AM
SiR 621's Avatar
i'm wondering the same thing...i've tried boosting over 14psi to reach somewhere around 300whp but the damn boost wont hold...can you guys tell me your secret and what kind of set up your running to reach 300+whp..
Old Mar 1, 2004 | 07:17 PM
swoosh's Avatar
Default Re: greddy 18g turbo how much power can it support? (SiR 621)
I am using a bigger downpipe/exhaust, and the wastegate is worked. Plus a built bottom end.
-swoosh
Old Mar 1, 2004 | 07:21 PM
BoostedITR41's Avatar
I am hoping for 330whp or better tuned on a stock bottom end so I would say you can do it on a built one....I have been runnin 15psi for 6 months and have no boost creep or spikes. get a profec-B that did it for me
Old Mar 2, 2004 | 01:33 PM
GPNY's Avatar
Default Re: greddy 18g turbo how much power can it support? (BoostedITR41)
Should be no problem. 18g turbos have put down 400 hp in talons.
I think forced performance 18g turbos flow 550-600 cfm
Just be sure to run a larger downpipe. I would also look into replacing the cast elbow with a tubular setup...
Old Mar 2, 2004 | 04:04 PM
swoosh's Avatar
Default Re: greddy 18g turbo how much power can it support? (Gpelsise)
Yeah I plan on using a bigger down pipe but I am worried about boost spike I know the wastegate is designed for a street legal setup and I have a thermal exhaust, but I don't think it is the 3" that I had ordered
Old Mar 3, 2004 | 09:25 AM
GPNY's Avatar
Here are the flow charts for dsm turbos http://www.m2g.com/index.php?o...=DESC
The wastegate is to bypass the turbine. At higher boost, you don't need the wastegate as much because you will not need to bypass the turbine as much...
Old Mar 3, 2004 | 09:50 AM
ProEater's Avatar
ive heard you shouldnt run over 13psi on a 18g turbo. you can still reach 300whp with 13psi and some other goodies though.
Old Mar 3, 2004 | 07:41 PM
GPNY's Avatar
Default Re: greddy 18g turbo how much power can it support? (ProEater)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProEater &raquo;</TD></TR><TR><TD CLASS="quote">ive heard you shouldnt run over 13psi on a 18g turbo. you can still reach 300whp with 13psi and some other goodies though.</TD></TR></TABLE>
You've heard wrong. The Dsm's run these over 20 psi.
Old Mar 3, 2004 | 08:49 PM
Andrew 825SM's Avatar
I get 250 whp at 11 psi boost which spikes up to 13 psi. I don't get how to hold boost with the 18g. My compression is 8.5:1 with a 3mm inline pro headgasket.
Old Mar 3, 2004 | 09:09 PM
boostin GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gpelsise &raquo;</TD></TR><TR><TD CLASS="quote">
You've heard wrong. </TD></TR></TABLE>
i'd like to see you run 20 psi on the 18g's internal wastegate.
can't avoid the spikes when u up the boost past 14psi.
i've had the greddy kit and it produced 295whp at 14psi on a stock gsr block, that's all you should really expect out of it. if u want more, try planning on a larger turbo.
eric
Old Mar 3, 2004 | 11:22 PM
roydogg's Avatar
Default Re: greddy 18g turbo how much power can it support? (boostin GSR)
The greddy kit sure is fun to drive when the boost gets past 12psi. I dynoed at 1 bar and my avcr holds it pretty solid all the way. Gonna upgrade to 3"dp, exhaust, skunk2 im, and crower402t's then up the boost to try to max it out. Hopefully 300-325. It spools up really quick and is a perfect street turbo
Old Mar 8, 2004 | 03:42 PM
iiilgsrlll's Avatar
Default Re: greddy 18g turbo how much power can it support? (roydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roydogg &raquo;</TD></TR><TR><TD CLASS="quote">The greddy kit sure is fun to drive when the boost gets past 12psi. I dynoed at 1 bar and my avcr holds it pretty solid all the way. Gonna upgrade to 3"dp, exhaust, skunk2 im, and crower402t's then up the boost to try to max it out. Hopefully 300-325. It spools up really quick and is a perfect street turbo </TD></TR></TABLE>
Are you still using the Greddy cast elbow for the downpipe?
Old Mar 8, 2004 | 07:18 PM
roydogg's Avatar
Default Re: greddy 18g turbo how much power can it support? (iiilgsrlll)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iiilgsrlll &raquo;</TD></TR><TR><TD CLASS="quote">
Are you still using the Greddy cast elbow for the downpipe? </TD></TR></TABLE>
yup
Old Mar 8, 2004 | 07:40 PM
GPNY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostin GSR &raquo;</TD></TR><TR><TD CLASS="quote">
eric</TD></TR></TABLE>
Look at the flow charts. It will produce up to 400 hp! I personally upgraded my turbine housing to the HRC 10cm housing, which remains internally gated.
The greddy internal wastegate spikes because it dumps into the cast elbow which causes turbulence and restricts flow. If you upgrade the elbow the turbo will not spike.
Everyone always says to go bigger for turbos, but it's not always necessary, and bigger turbos will lag more
Old Mar 8, 2004 | 08:07 PM
bisket's Avatar
that's an ignorant statement.
my friends gst spyder had the greddy 18g kit on and ran 20 psi daily, no spiking. held solid. no dyno though, sorry.
swoosh, take everything you read on HT with a grain of salt. do your research, go to some dsm boards and ask around there too.
Old Mar 9, 2004 | 02:03 PM
Maxime's Avatar
Default Re: greddy 18g turbo how much power can it support? (Andrew 825SM)
I did 238 whp with 7psi of boost with an custom 2.5" downpipe and 3" exhaust.
Old Mar 9, 2004 | 02:32 PM
Turbo E's Avatar
Greddy Says four-hunnerd
Old Mar 9, 2004 | 03:14 PM
dc-lefty's Avatar
Default Re: (Turbo E 604)
BUMP. also runnin the 18g. any more comments ??
Old Mar 11, 2004 | 03:50 PM
swoosh's Avatar
Default Re: (dc-lefty)
All I have is the pipe with the o2 sensors made bigger how can you upgrade the cast piece that is hooked to the turbo.
-swoosh
oldskool1111
Feb 24, 2010 07:22 PM
GreddySi99
Jul 9, 2003 10:29 AM
willyboyK20
Nov 8, 2001 12:59 PM
boost killz
Oct 8, 2001 07:32 AM
