can a 84.5mm headgasket be used on a 84mm bore?
Old Feb 28, 2004 | 08:25 AM
turboex's Avatar
Default can a 84.5mm headgasket be used on a 84mm bore?
Just as i ask, need to know if ill have an problems running a 84.5mm hg on a 84mm bore Reason i ask is cause i hear hoda stock head gaskets are a tad over sized. thanks
Old Feb 28, 2004 | 01:00 PM
turboex's Avatar
Default Re: can a 84.5mm headgasket be used on a 84mm bore? (turboex)
TTT any ideas guys?
Old Feb 28, 2004 | 01:13 PM
PureTeg420's Avatar
it can be done, but make sure you use copper spray
Old Feb 28, 2004 | 01:21 PM
turboex's Avatar
Default Re: can a 84.5mm headgasket be used on a 84mm bore? (PureTeg420)
why the coper spray if its a stock gasket? its honda part just bored by GE. thanks for you imput
Old Feb 28, 2004 | 01:39 PM
PureTeg420's Avatar
it has a better chance of sealing completely if you use copper spray
Old Feb 28, 2004 | 02:11 PM
turboex's Avatar
Ah, would it be better to just get the right gasket?
Old Feb 28, 2004 | 02:28 PM
Kelly.'s Avatar
I've quit using this account
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboex &raquo;</TD></TR><TR><TD CLASS="quote">Ah, would it be better to just get the right gasket?
what kinda question is that?
of course it would be better to get the right HG. if you arent gonna do that, then use copperspray.
Old Feb 28, 2004 | 02:34 PM
showtymers619's Avatar
* B A N N E D *
Default Re: can a 84.5mm headgasket be used on a 84mm bore? (llewsirc)
stupid is stupid does
Old Feb 28, 2004 | 03:01 PM
turbo96wr's Avatar
you could use that headgasket but if you do research on copper spray it does not dry with the heat and creates head movement, even with the dowel pins.
Old Feb 28, 2004 | 03:47 PM
LudeyKrus's Avatar
Simple answer: yes, you can.
The copper spray is just a good thing to do w/ head gaskets.
Old Feb 28, 2004 | 04:27 PM
turboex's Avatar
Default Re: (LudeyKrus)
Did not need the hating but hey what can you do.. The reason i asked this is cause i have read before that stock honda head gaskets are over sized. I was wondering buy how much so that i could work something out. But hey ill just order another gasket. thanks for the help.
Old Feb 28, 2004 | 04:34 PM
alpha's Avatar
Do you already have the 84.5mm head gasket?
Old Feb 28, 2004 | 04:36 PM
turboex's Avatar
Default Re: can a 84.5mm headgasket be used on a 84mm bore? (0x64)
yes i do. Got the wrong one, its from goldeneagle
Old Feb 28, 2004 | 04:38 PM
alpha's Avatar
Call Vince tomorrow afternoon and talk with him. He is a nice guy. I'm willing to bet he will exchange it for you. You are resleeved so I say get the 84mm head gasket.
Old Feb 28, 2004 | 04:39 PM
turboex's Avatar
Thanks man ill give him a call, its on a dart block.
Honda_Tech01
Jun 23, 2008 08:42 AM
hondaapi
Oct 20, 2004 09:42 PM
ITRNoah
Apr 22, 2004 09:21 AM
jdm_redneck
11
Mar 16, 2004 09:37 PM
senpai
Jun 17, 2003 05:39 PM
