Headgasket question
Old Jun 17, 2003 | 01:32 PM
senpai's Avatar
Default Headgasket question
Can I use 76mm headgasket with a 75.5mm bore? I got the wrong Cometic headgasket. I asked for 75.5mm ...
Old Jun 17, 2003 | 01:44 PM
thid92's Avatar
can I haz?
send it back or get a OEM and get it bored at the machine shop
Flamenco-T's Avatar
Default Re: Headgasket question (maztur)
you may be able to sand down the edges and get a lil shavings off. I was able to use an 81mm gasket in a 81.5m bore. but that's the other way around, It works fine.
stan
Old Jun 17, 2003 | 05:39 PM
senpai's Avatar
Default Re: Headgasket question (Flamenco-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T &raquo;</TD></TR><TR><TD CLASS="quote">you may be able to sand down the edges and get a lil shavings off. I was able to use an 81mm gasket in a 81.5m bore. but that's the other way around, It works fine.
stan
So I should be okay, even thought its +0.5mm?
Honda_Tech01
Jun 23, 2008 08:42 AM
EK FLY
Aug 14, 2006 06:31 PM
Master23
Mar 8, 2006 01:18 PM
hondaapi
Oct 20, 2004 09:42 PM
turboex
Feb 28, 2004 04:39 PM
