who knows exactly what i need to do a itr suspension swap
Old 10-14-2001, 03:14 PM
New User
PROFILE EK4's Avatar
Default who knows exactly what i need to do a itr suspension swap
im planning on goin with a itr suspension in my ek....who has done this and wat exactly do i need to make this work....only knowledgeable people need reply
thanks in advance
Old 10-14-2001, 03:30 PM
newspeedR's Avatar
Default Re: who knows exactly what i need to do a itr suspension swap (PROFILE EK4)
actually, i think the question should be is the upper control arm different er the same as 1 from a integra... the mounting positions are differnt on the chassis, but are the arms the same...
Old 10-14-2001, 03:40 PM
jonas's Avatar
i did the conversion a couple weeks ago.. you will need the hubs, rotors, brake pads, ebrake cables, integra type r master cylinder and brake booster, and the wheels of course. be careful, you also need a proportioning valve, but the one off the type r wont fit because its going into your EK chassis, so use the 99-00 civic si proportioning valve.
dont forget to get ALL THE BOLTS needed, i was missing a few caliper bolts, and acura charges an arm and a leg for integra type r parts...
the lower control arms will NOT fit on an EK chassis, nor will the shocks or springs, front or rear sway bars.
hope that helps, i'll post more if i forgot anything.
Old 10-14-2001, 03:51 PM
New User
Battousai's Avatar
I am also intersted in doing this conversion on my 00 Civic Si. Am I going to face the same problems with the lower control arm on my car or is it diffrent from the Ek?
Old 10-14-2001, 04:10 PM
jonas's Avatar
Default Re: who knows exactly what i need to do a itr suspension swap (Battousai)
im not sure if the lower control arms will fit on the si or not.. but if they dont, its not a problem. you dont need them to do the 5 lug conversion.
Old 10-14-2001, 07:38 PM
bigTom's Avatar
Default Re: who knows exactly what i need to do a itr suspension swap (jonas)
the only reason for the lca is to fit the itr strut... the knuckles/brakes/etc. the complete assembly bolts up without springs/shocks... the itr shocks are differant from stock civic shocks in the way they bolt up to the lca
Old 10-14-2001, 07:48 PM
New User
EGgood's Avatar
Default Re: who knows exactly what i need to do a itr suspension swap (ek9t)
Nothings diffrent
It all bolts up
you will need the 4 wheels disc proportioning valve
it isnt a must but, its nice to get the R master cylinder, it feels very diffrent
gette entire suspension if you can, thats what i did
check it out here- http://hometown.aol.com/eg6good/
Old 10-14-2001, 07:51 PM
New User
EGgood's Avatar
Default Re: who knows exactly what i need to do a itr suspension swap (EGgood)
oh ****! nevemind you got a new one, hmm i think you can just swap the hub, and lower control arms for te EK
ha, sorry, i didnt even read the post until i posted
Old 10-14-2001, 11:12 PM
New User
Battousai's Avatar
So! In steps (I'm rather new a this), what is it exactly that I need to get the 5 lug conversion done perfectly on my 2000 Si?
Old 10-15-2001, 09:43 AM
jonas's Avatar
http://hybrid.honda-perf.org/tech/5lug.html
that is the step by step for an EG..
but you said you have a 99-00 civic si... you would have to use your proportioning valve, and you dont need to swap the LCA's.
everything else is about the same. hope that helps.
Old 10-16-2001, 08:34 AM
New User
Battousai's Avatar
Last question, I promise What about the brake lines? Do I have to replace those on my 2000 Si ? If so which ones would work ? O.k. more than one question.
TroyLee
01-13-2011 04:58 AM
JDMorgan
03-21-2005 04:11 AM
vtecpower1062
03-27-2004 11:31 PM
RoAnSa
12
11-24-2002 07:54 AM
speedracr
09-29-2002 02:00 AM
Quick Reply: who knows exactly what i need to do a itr suspension swap
