How high can you make a 3psi spring go in a tial 38mm wastegate?
Old Feb 23, 2004 | 08:35 AM
gdrum's Avatar
Default How high can you make a 3psi spring go in a tial 38mm wastegate?
I want to get a 3psi spring for h22 for daily driving because its plenty of power...then use a boost controler to take it to 6, 8 then who knows. But just curious what is max that can be taken to before its to small.
Old Feb 23, 2004 | 08:54 AM
Johnyquest's Avatar
Default Re: How high can you make a 3psi spring go in a tial 38mm wastegate? (gdrum)
A 3 psi spring will barely be enough boost to spin the turbo never mind overcome the restriction imposed upon your exhaust by the turbo. It's not worth it. Get the .5 bar spring, minimum. 6psi is plenty low for daily driving, and you can run up to 12 on it. Supposedly, you can't (shouldn't) boost more than 2x the spring's rating. I don't know why this is the case, but don't get a 3psi spring.
Old Feb 23, 2004 | 09:39 AM
DaX's Avatar
DaX
Loved
Community Favorite
You can double your spring rate with a boost controller, so 6 psi.
Old Feb 23, 2004 | 09:45 AM
bluebullet's Avatar
Default Re: (DaX)
This information is incorrect you guys are providing. You <U>can</U> go higher than two times the wastegate spring with a boost controller.
Old Feb 23, 2004 | 10:09 AM
JDEM1's Avatar
Default Re: (bluebullet)
they never said it was impossible.. they said it SHOULD NOT be done.. not CANNOT...
Old Feb 23, 2004 | 10:18 AM
gdrum's Avatar
Default Re: (JDEM1)
Right but i was told i needed a 3psi spring which is more then enough to save the h22 and its plenty for daily driving given the motor itself is pleaty for daily driving...then boost controler to crank it up. It makes sense seeing how the t3/t4 performs at 6psi......so i think i might do that..but not sure other opinions?
Old Feb 23, 2004 | 11:54 AM
Muckman's Avatar
Moderator in Chief
Default Re: (gdrum)
And you can never boost less than the spring rate? even with a EBC? or is that incorrent?
Old Feb 23, 2004 | 11:57 AM
Burke's Avatar
Banned
Default Re: (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">And you can never boost less than the spring rate? even with a EBC? or is that incorrent?</TD></TR></TABLE>
correct
Old Feb 24, 2004 | 11:48 AM
gdrum's Avatar
Default Re: (Burke)
maybe itd be a good idea for 3psi spring for launching at the track.....then get a dual stage boost controler....lay into 2nd at 6psi.....torque off the line sucks.
Old Feb 24, 2004 | 12:18 PM
808b18c1boosted's Avatar
Default Re: (gdrum)
you can boost as high as you like with a 3psi spring as long as you have a .
boost controller
Old Feb 24, 2004 | 01:55 PM
brickonwheels's Avatar
do you guys know of any good threads or pages where i can get info as to how the boost controller actually controls boost?
SilverWarrior
Mar 30, 2008 03:32 PM
Garage 808 Hatch
Dec 4, 2006 08:22 PM
Cyber ITR
Jan 19, 2004 03:38 AM
W.Zero
Oct 28, 2003 11:42 PM
Turbo_Teg
Jan 14, 2002 07:35 PM
