wastegate spring
Old Dec 3, 2006 | 02:12 PM
Garage 808 Hatch's Avatar
Default wastegate spring
does anyone know where i can get a heavier spring for a turbonetics evolution wastegate? i cant find one stiffer than the 9 psi spring. looking more for like a 17-20psi spring
Old Dec 3, 2006 | 02:20 PM
Mugencrxsir1's Avatar
Default Re: wastegate spring (Garage 808 Hatch)
You can always double two springs up, and 2 9lbs springs will give you 18lbs? I don't believe you will find a spring that heavy, and especially for a 35mm wastegate. Plus you don't need a wastegate spring that high if you have an electronic boost controller, and if you don't, you probably should get one........... If you what to run 18-20psi, then run a 9-10lbs spring, and let the boost controller do the rest....
Old Dec 3, 2006 | 04:46 PM
Default Re: wastegate spring (Mugencrxsir1)
i have a turbosmart dual stage manual boost controller. i plan to run 18-22psi low boost(depending on the power yielded) and 35ish psi high boost.
Old Dec 4, 2006 | 08:22 PM
anyone?
powerdbygarrett
Jul 3, 2008 01:50 PM
dunkd
Feb 3, 2005 11:45 AM
gdrum
Feb 24, 2004 01:55 PM
wonny
May 30, 2002 03:18 PM
Turbo_Teg
Jan 14, 2002 07:35 PM
