TPS PROBLEM??
Old Feb 20, 2004 | 12:33 AM
CrXr89Si's Avatar
Default TPS PROBLEM??
I have an 89 crx si, just had some work done on the head and now that im putting it back together the idle is all screwed up.
Ive tried resetting the ECU a few times and it works when the TPS is unplugged but when i plug in the TPS it revs straight to 2500. Also the check engine light is on, not sure what from.
Any help is much appreciated.
Old Feb 20, 2004 | 06:27 AM
88strippedhatch's Avatar
Default Re: TPS PROBLEM?? (CrXr89Si)
Try using a Volt meter and check what the Tps is doing it should read 0-4.5/5v depending on position. Sounds like it is sticking and not going to .01 or whatever
Old Feb 20, 2004 | 06:36 AM
crx_88_si's Avatar
Default Re: TPS PROBLEM?? (88strippedhatch)
TPS 0.45v to 0.5v for CLOSED throttle and 4.5v to 5v for Full Throttle.
check ALL your vacuum connections as well.
Old Feb 20, 2004 | 08:53 AM
WONG FRIED RICE's Avatar
did u touch the idle adjustment screw? Throttle cable too tight? FITV? IACV clean? TPS clean?
Old Feb 20, 2004 | 10:00 AM
CrXr89Si's Avatar
Default Re: TPS PROBLEM?? (JDMB16ACRX)
Yes i adjusted the idle screw and i checked the throttle cable a few times neither of those seem to be the problem.
sorry im kind of newb what are FITV? IACV?
The TPS has a crack on the black part of the plug could this be the problem?
Thanx for help btw.
Old Feb 20, 2004 | 10:07 AM
FITV is fast idle thermal valve, IACV is idle air control valve
about the crack on the TPS, i don't think the crack should be the problem, but do look into it just in case
Old Feb 20, 2004 | 10:50 AM
CrXr89Si's Avatar
Cool thanx alot im going down to the shop here in bout an hour ill let you guys know how it goes.
Also installing a fuel level gauge and a engine temp gauge.
Old Feb 20, 2004 | 12:44 PM
good luck!
Old Feb 21, 2004 | 06:54 PM
CrXr89Si's Avatar
Turns out it was a shitty ecu that the aftermarket company gave me i put my stock one in and now it runs great! hewl yea.
Old Feb 23, 2004 | 08:26 AM
the simplest things sometimes.....
MastaFlyMason
May 5, 2013 07:24 AM
95civic16
Jul 20, 2008 05:44 PM
latinracerct
Jan 10, 2008 10:21 AM
urbanbrown
May 2, 2005 10:11 AM
eknine
Jul 10, 2003 08:36 AM
