idle problem... help please
Old Jul 10, 2003 | 07:13 AM
eknine's Avatar
Default idle problem... help please
when im driving my idle stays pretty high like at 2200 but when i come to a complete stop it will go down to 1600, but its not a slow deceleration, the moment my car stops fully, then it drops, after it gets warm, if i turn off the car and turn it back on it will drop to 2000 at a roll and 1200 at a stop, if i get out of the car and push on the throttle wheel towrds closing it, i can get it to go down to 900 at a stop, and it will stay there. hmmm i really need help...
Old Jul 10, 2003 | 07:18 AM
devonic's Avatar
any codes? my cars been doing sort of the same but when i come to a stop it keeps the idle at like 1500, have to hold the brake tight or it will roll forward
Old Jul 10, 2003 | 07:44 AM
2camsaam's Avatar
Default Re: (devonic)
May want to check to see if there is too much tension the throttle cable.
WD-40 the throttle cable spring by they throttle body, maybe its not releasing freely.
Check your TPS
If this doesn't do it then, adjust the throttle valve w/ flat head screw driver.
Old Jul 10, 2003 | 08:36 AM
granada_sun's Avatar
theres an idle screw on the bottom of the throttle cable side of the throttle body, try adjusting that to lower rpms.
prolly easing some tension on throttle cable would help too. good luck, lates.
therealmccoy
Jun 8, 2018 09:31 AM
FATKID87
Honda CR-V & Element
Mar 26, 2014 07:52 AM
cdmef
Jul 3, 2011 06:03 AM
hybridEj6
Oct 5, 2006 11:23 AM
shooitzlinh
Jan 8, 2005 09:52 PM
