idle probs??
Old May 1, 2005 | 04:51 PM
urbanbrown's Avatar
Default idle probs??
hey im new to the forums and i need some help
i have a 1991 integra 4dr and when i start it it revs to 3000 rpmand i put my hand over the throttle body and it doesnt stop it if anyone could shed some light on this it would be greatly appreciated
thanks, George
Old May 2, 2005 | 05:01 AM
JimBlake's Avatar
Default Re: idle probs?? (urbanbrown)
Look for vacuum leaks & fix them.
Check throttle cable & linkage to be sure throttle is able to close completely.
Clean IAC & FIT valves, & clean the throttle bore where the throttle plate closes.
If that doesn't work, search for 'base idle' adjustment & do that.
Old May 2, 2005 | 09:06 AM
Katman's Avatar
..also check and see if you put the TB gasket on the wrong way.
Old May 2, 2005 | 10:11 AM
slowdx's Avatar
^^^ listen to them.
Kman1371
Feb 14, 2017 08:22 AM
powerstrokeaaro
Aug 22, 2010 04:20 AM
handa
19
May 24, 2005 03:43 AM
EKtypeRhaTcH
15
Nov 29, 2004 10:47 AM
Shft@9GSR
Nov 15, 2002 11:21 AM
