need an END-all wiring for VX 5wire to 4wire chart w/Vx harness & P28 ecu
Old Feb 19, 2004 | 05:10 PM
dremmel's Avatar
Default need an END-all wiring for VX 5wire to 4wire chart w/Vx harness & P28 ecu
ok i mustve read 6 threads or countless posts on how its done, but with a vx harness with a DOHC motor, &/or various B series ECU's. It would be very very nice for the easiest o2 conversion for a obd1 VX 5-to-4 wiring conversion using the stock VX harness and either VX ecu; EX/Si P28 sohc ecu . . Pics also greatly help the electronically/anxiety impaired such as myself . Gracias
PS thanks 2 those whove answered my many ?'s but i get nervous/slow with wiring.
Old Feb 20, 2004 | 11:55 AM
civicminded92's Avatar
Default Re: need an END-all wiring for VX 5wire to 4wire chart w/Vx harness & P28 ecu (dremmel)
PM'd you back dremmel, but thought that I'd post it here for anyone else:
You only have to move the one wire - that's it! No need to be intemidated man!
Good luck!!!
Old Feb 20, 2004 | 02:04 PM
dremmel's Avatar
Default Re: need an END-all wiring for VX 5wire to 4wire chart w/Vx harness & P28 ecu (civicminded92)
*bows* im not worthy...... a zillion ! (beer emote). i will try this today
Old Feb 21, 2004 | 09:52 AM
dwnthehatch's Avatar
Pics and complete how-to
http://www.hondaswap.com/forum...14242
Old Feb 23, 2004 | 11:47 AM
Default Re: need an END-all wiring for VX 5wire to 4wire chart w/Vx harness & P28 ecu (dwnthehatch)
dwnthehatch,
According to the linked to thread D16 is to be moved also. I haven't moved the D16 pin, but my setup is working flawlessly. No CEL's, good gas mileage - for some reason it is working, even though the factory service manual shows something different. I will look further into this and try and figure out why mine is working and it possibly shouldn't be. But, I will say that it does 100% work and I currently have no reason to change it -
dremmel,
I would suggest using the method that I came up with - simply because you will have to do it either way. Try it with only moving the Pin that I suggested and let me know if you have ANY problems - I'll be very supprised if you do.
Keep us updated - I'm off to try and figure out why what I have is really working....and has been for 35k miles!!!!
Old Mar 1, 2004 | 10:29 AM
dremmel's Avatar
i tried that with my VX harness & p28 ecu... code popped up after i started it. Just bought a EX harness from wrecking yard...hope it works with stock o2 4wire plug & jdm intake manifold...i had to tap into a vacuum line from the fuel pressure regulator to the Purge vap which is usually mounted on the back drivers side of IM. ill get back
Old Mar 1, 2004 | 10:33 AM
dremmel's Avatar
crap i just noticed my "eX" harness i bought has only 3 Connectors on the passenger side shock tower. the VX harness going from my P28 ecu to that shock tower on pass side has 4 connectors.
Old Mar 1, 2004 | 10:41 AM
That's normal. The extra plug is for the vtec-e motor. Just let it hang.
Old Mar 1, 2004 | 09:17 PM
dremmel's Avatar
aaah ok, i got a lil worried there.i getcha now, it prolly was for that other egr thing by the head & vtec solenoid right? cool, i just have a code 14 now.
hatchback33
Jun 2, 2010 10:42 PM
slowbluhatch
Apr 13, 2005 07:34 AM
Mentat Ghola
Oct 22, 2004 04:11 PM
URBAN TANK
Jun 22, 2004 10:44 AM
meanTheDope
Apr 28, 2004 08:58 AM
