What kind of OEM bearings do I use?
Old Feb 19, 2004 | 10:58 AM
85mm LsVTEC's Avatar
Default What kind of OEM bearings do I use?
I need OEM bearing for my LS crank and need to know what color to tell the dealer to order.
Old Feb 19, 2004 | 12:01 PM
dfoxengr's Avatar
Default Re: What kind of OEM bearings do I use? (85mm LsVTEC)
look at the color you have and get the same.
Old Feb 19, 2004 | 12:03 PM
MightyMouseTech's Avatar
You need the codes off of your block and crank and look up what colour code that coresponds with. That is the ONLY way to do it.
Old Feb 19, 2004 | 04:54 PM
Default Re: What kind of OEM bearings do I use? (MightyMouseTech)
That's exactly what I needed guys, thanks.
Old Feb 19, 2004 | 07:20 PM
dfoxengr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MightyMouseTech &raquo;</TD></TR><TR><TD CLASS="quote">You need the codes off of your block and crank and look up what colour code that coresponds with. That is the ONLY way to do it.</TD></TR></TABLE>
when i replace bearings in my friends LS his were red, so we got red. theres a MATCH
Old Feb 19, 2004 | 07:23 PM
InjectedPerformance's Avatar
We sell parts.
Default Re: What kind of OEM bearings do I use? (hybridvteceg)
Most of the time you can not see the color on the bearing. So you need to do what mighty mouse said. Also i would double check with a plasti gauge.
dc4teg95
15
Aug 14, 2008 07:18 PM
averyvm
Feb 15, 2007 08:05 AM
SidewayzSupra
Dec 4, 2006 11:32 AM
simike
Mar 21, 2005 08:42 AM
95gsr
Nov 6, 2003 07:04 PM
