purple green red violet can someone help me with these bearings I SEARCHED
I posted some pictures of what it says on my crank and block can you help me from here just tryin to buy some new bearings. first build
On the block it say CCBCC
and here are some pictures I did it myself
Modified by averyvm at 10:33 PM 2/14/2007
Re: (Dunn@ImportTurboSolutions)
Actually you already have it listed above. You take what is listed on the crank for the code, and then decifer it into the color that is on your chart.
IE: B 2 = yellow
Are you looking for oem/acl standard sizes? if so I can just give you the part numbers
IE: B 2 = yellow
Re: (averyvm)
You have to use the letters on the block AND the numbers on the crank, like stated above. If the #1 main journal on the block says B, and the #1 main journal on the block says 2, then see B2.
Re: (ccivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccivic »</TD></TR><TR><TD CLASS="quote">You have to use the letters on the block AND the numbers on the crank, like stated above. If the #1 main journal on the block says B, and the #1 main journal on the block says 2, then see B2.</TD></TR></TABLE>
thats for the MAINS, above
and then you use LETTERS on the crank, with NUMBERS on the rods to get rod bearings.
if you got eagles, there supposed to be all 3's
Re: purple green red violet can someone help me with these bearings I SEARCHED (averyvm)
thank you guys so much everything just clicked
I never saw the numbers on the rods Damn I feel so stupid thanks alot guys
ruffrhyder
21
08-27-2008 06:14 PM
