oil pressure problem with LS/vtec turbo. no vtec
Old Feb 18, 2004 | 04:51 AM
Griffin@Camtech's Avatar
Default oil pressure problem with LS/vtec turbo. no vtec
See if some can help me out with this.
I am running a LS /vtec that we installed a turbo on monday. Before the turbo the motor would run abput 80 PSI of oil pressure before vtec hit. The oil feed for the turbo was added to the to the same tee. now it runs 55-60PSI before vtec. Vtec will come on but then it falls back out. (to little oil pressure??)
whats you guys thoughts?
Thanks
Old Feb 18, 2004 | 04:56 AM
MIKES's Avatar
Default Re: oil pressure problem with LS/vtec turbo. no vtec (EK2NR)
doesn't seem that hard of a decsion to me. Find another spot to take your oil feed for the turbo. Or just get a GE oil filter adapter with the multi ports and call it a day.
Old Feb 18, 2004 | 05:21 AM
BROOD's Avatar
What size oil lines are you using to feed the cyl head and turbo? Where does the turbo line tee into the cyl head line?
Once the Vtec spool opens the oil consumption rate will increase. Sounds like the set-up you are running can't support enough to keep Vtec oil psi above desired pressures.
I have good luck using a 6AN line to the cylinder head while stealing oil just before the cyl head fitting to use for the turbo lube. I stick to a 3AN turbo line. Although I just switched to a GEM adapter, keep the 6AN feed to the cyl head, and am using a 4AN restricted feed to the turbo. No cyl head oil starvation, no oil carryover at the turbo, runs great.
I'd say up your main feed from 4AN to 6AN and possibly use a tee with larger internal openings.....you will probably not have any problems then.
Modified by BROOD at 7:43 AM 2/18/2004
Old Feb 18, 2004 | 05:49 AM
Default Re: oil pressure problem with LS/vtec turbo. no vtec (BROOD)
There is a Tee mounted on the firewall a 4AN line from the block to the tee. the head is fed thru a 4an and the turbo thru a line one size smaller (6an? I think?)
Thanks for the help guys
Old Feb 18, 2004 | 08:19 AM
top
Old Feb 18, 2004 | 08:47 AM
Rtype16's Avatar
Buy the golden eagle adapter and call it a day. Also which oil pump are you using.
Old Feb 18, 2004 | 09:11 AM
Default Re: oil pressure problem with LS/vtec turbo. no vtec (Rtype16)
GSR
Old Feb 18, 2004 | 09:36 AM
Rtype16's Avatar
GSR pump should be fine. I would suggest to get the Golden Eagle adapter and use that for your feed lines. Do you have a reducer in your turbo feed line?
Old Feb 18, 2004 | 09:49 AM
no reducer. its the standard line for a drag gen 3 kit.
were can I get the golden eagle peice?
Thanks
Old Feb 18, 2004 | 11:09 AM
up
Old Feb 19, 2004 | 08:07 AM
Rtype16's Avatar
From Golden Eagle do a search.
Old Feb 19, 2004 | 08:11 AM
Silverbeast's Avatar
Contact lightning (tom) he stocks GE and has those in stock.
Old Feb 21, 2004 | 06:15 AM
Thanks guys I got the golden eagle peice and the problem is fixed.
Thanks again
Old Feb 24, 2004 | 03:01 PM
saleensolution's Avatar
this is how i ran my oil lines for vtec, i used a vtec oil pump and relocate the oil sending unit on the head. see if that helps you any
Old Feb 24, 2004 | 03:13 PM
brasilstreet's Avatar
Default Re: oil pressure problem with LS/vtec turbo. no vtec (saleensolution)
how much power you got in ur ls/vtec? ^ im building mine up now i got a b16 head ls shortblock and b16 transmission.
Old Feb 24, 2004 | 03:24 PM
Default Re: oil pressure problem with LS/vtec turbo. no vtec (brasilstreet)
never dynoed it, just dradded it
Old Feb 24, 2004 | 03:40 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
i don't like the way the fitting comes off the block. I've seen those fittings break off the block and people lose there motors behind it.......just my .02. otherwise looks good except for the manifold. I ran my line with that heavy fitting mounted on the firewall so it wont put stress on the block
Old Feb 24, 2004 | 04:20 PM
Default Re: oil pressure problem with LS/vtec turbo. no vtec (HybridcivicLS-T)
this is a motor that i built for a guy he took he cheap way with the mani, but i used this oil set up on 3 engines and havent had a problem the sending unit hole was bored out for less rescrictive flow
Old Feb 24, 2004 | 05:58 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saleensolution &raquo;</TD></TR><TR><TD CLASS="quote">this is a motor that i built for a guy he took he cheap way with the mani, but i used this oil set up on 3 engines and havent had a problem the sending unit hole was bored out for less rescrictive flow</TD></TR></TABLE>
that's cool it just happend to my buddies block from viberation, just don't want to see it happen on a good motor. I think that's the worst way to lose a motor.
madcrx69
Apr 17, 2010 05:31 AM
Aladar
Mar 2, 2008 09:44 PM
GaVO311
Sep 12, 2006 08:30 PM
DXK Eg
Mar 31, 2004 10:58 AM
lswithvtec
Nov 27, 2001 11:06 AM
