Going from pick and hold to saturated injectors need HELP!!!
First of all I have already searched, this is my dilema. I was running 450cc with the resistor box in my eg, came a round a good deal with some RC 550cc saturated so I bought them, anyway the injectors are already install, I have removed the resistor box, but I cant remeber which wires go with each other. Obiously they are all the same color does it matter how they go or just match to any wire?
It won't matter for OBD-1 cars. The 8 yellow with black stripe wires on the engine harness all are for a common ground. They go to:
4 of them ground the 4 injectors
1 of them grounds the charcoal canister purge solenoid
1 of them grounds the IACV
1 of them grounds the 4 wire o2 sensor
1 of them runs to the body harness on the driver side
That's 8 wires, and it doesn't matter which way you run them, as long as each component gets one of the wires.
turbo_ef9
Jan 24, 2005 09:47 AM
